MAF Cleaning (used to be "Technical Forum")
Joshie Jan 6, 2003
  1. Joshie
    Joshie Member
    71
    Is this forum missing?
    And who will be the first to post a question about cleaning MAF's or servicing dump valves? /ubbthreads/images/graemlins/grin.gif
  2. AL_B
    AL_B Well-Known Member
    1,670
    82
    I think it would be good to have.
    AL
  3. toasty
    toasty Member
    52
    I 'cleaned' my MAF the other day.
    Not a sausage, it was as clean as the driven snow.
    So now I have 900ml of Isoprop Alcohol left..... I wonder what it tastes like!
    -Dan
  4. audi_girl
    audi_girl Active Member
    1,038
    Ok blonde moment.... MAF ???
  5. Joshie
    Joshie Member
    71
    ...............Mass Air Flow (Sensor)
    It senses how much air is passing over it and then relays this information to the ECU so that fuel air mixture is regulated.
    Dirty MAF's cause turbo lag and general hesitation.
    .what an anorak I've become /ubbthreads/images/graemlins/grin.gif
  6. toasty
    toasty Member
    52
    Mass Air Flow sensor
    A hot wire sensor which monitors the flow of air past by means of the change in temperature the airflow causes (more air cools the hot wire more)
    This info is then passed to the ECU which controls the amount of fuel going into the cylinders accordingly.
    When they get dirty, they are effectivly insulated from the cold air breeze and hence think less air is going in, and therefore provide less fuel. This makes the car run lean, and hence run slower (which is bad!)
    I don't think it is such an issue on the newer cars (like your S3) but certainly on the older motronic S4 (pre 99.5) it was quite common.
    I think the newer MAFs (Mass Air Flow Sensors) are self cleaning, in a similar way to self cleaning ovens, they heat up so hot that they burn the dirt off.
    Hope this helps.
    -Dan
  7. Joshie
    Joshie Member
    71
    [ QUOTE ]
    [/ QUOTE ]
    Bet you're sorry you asked /ubbthreads/images/graemlins/grin.gif
  8. audi_girl
    1,038
    No /ubbthreads/images/graemlins/smile.gif
    So you reckon mine wouldn't need cleaning?
  9. toasty
    toasty Member
    52
    I wouldn't have thought so.
    I mean mine was spotless and I have the older version.
    To be honest I can't really see how any dirt could get through the airfilter anyway (unless you are running a K&N or similar performance filter)
    I reckon most people who clean them are just seeing the dirt from that had collected on the top of the sensor (the bit that is exposed to the world under the bonnet.
    Although someone (I think it was Ian) said that they noticed an improvement after cleaning, so who knows?
  10. ChrisT
    ChrisT Member
    57
    10
    Well if you've got all that alcohol going spare, you can pop over and clean mine if you like /ubbthreads/images/graemlins/wink.gif just round the corner!
    Cheers,
    Chris.
  11. audi_girl
    1,038
    Hope you don't mind - just changed the name of the thread as the subject changed.....
  12. Administrators
    Administrators Administrator Staff Member Administrator Audi A4 TDi
    3,976
    588
    MAP is Manifold Air Pressure, slightly different to a MAF
    most of you don't have MAF's!
  13. audi_girl
    1,038
    Who does have a MAF then?
  14. toasty
    toasty Member
    52
    I do....
    Or at least I hope so... Feck knows what I cleaned if I don't have one!
    I think all 2.7Ts have one (S4, RS4, Allroad turbo & A6)
  15. danksy
    danksy Member
    75
    anyone got a Halve Actuated Independent Recycling Yaw MAF? /ubbthreads/images/graemlins/blush.gif
    IMHO its a waste of good alcohol, and time and effort cleaning your MAF, anyone disagree?
  16. Administrators
    3,976
    588
    [ QUOTE ]
    I do....
    [/ QUOTE ]
    you probably cleaned the MAP lol /ubbthreads/images/graemlins/laugh.gif
  17. Drill
    Drill Member
    928
    [ QUOTE ]
    [/ QUOTE ]
    Well, to be honest, the first time I cleaned my MA(F)(P) /ubbthreads/images/graemlins/tongue.gif
    it was dirty enough to have a visible effect on the alcohol /ubbthreads/images/graemlins/frown.gif I've cleaned it about 3X since putting in my K&N panel, and it's been fairly clean each subsequent time.
  18. Joshie
    Joshie Member
    71
    I think if you're using an oil based fiter like a K&N then there is a requirement to clean the MAF from time to time. The standard cardbourd Audi air filer does not necessitate MAF cleaning.
    Anyone agree?
  19. AL_B
    1,670
    82
    I agree.
  20. Drill
    Drill Member
    928
    I second, your agreement /ubbthreads/images/graemlins/tongue.gif
  21. richyboy
    richyboy Member
    41
    Agreed. i just run a std paper filter cos of that
  22. AL_B
    1,670
    82
    Rich,
    Me to. K&N panel is sat in a cupboard somewhere. Can anyone think of some alternative uses for it? /ubbthreads/images/graemlins/smile.gif
    AL
  23. Jon
    Jon Member
    180
    [ QUOTE ]
    Rich,
    AL
    [/ QUOTE ]
    That answers my question of, are K&N's worth putting in an S3 /ubbthreads/images/graemlins/wink.gif
    Jon.
  24. Joshie
    Joshie Member
    71
    Well I'm using a K&N filter because it is claimed to increase airflow and horsepower. Am I right in thinking that these claims are not justified?
    Have their been any independent tests apart from the one referred to by K&N?
  25. toasty
    toasty Member
    52
    Joshie,
    I don't think it would make too much difference on a standard car like mine.
    ....but then yours is far from standard!! /ubbthreads/images/graemlins/grin.gif
    I'd would have thought the standard audi airbox and filter combo were designed with 265bhp in mind, perhaps you could stratch this a bit, but 400hp's worth of air will surely struggle to get through!
  26. Joshie
    Joshie Member
    71
    Well K&N make some ambitious claims about BHP increases on their packaging.
    When I had my car dynod at AMD before the mods and running the Abt 310HP chip, a Milltek Cat-back and the APR bi-pipe (as well as the K&N) I was getting 316BHP. The standard ECU produced 272. So that is an increase of 44 BHP for the Abt chip.
    Given the Abt's ECU produces 309BHP, this leaves 7HP for all the other mods so possibly the K&N claims are a bit over the top.
    The only way to test this would be to put the car on the dyno and run it with or without the K&N and see if there is a difference. The only problem with this suggestion is that the dyno plot is not consistent - so many things to affect the final result.
  27. Drill
    Drill Member
    928
    Well, I have had a K&N in my A3 for a bit over a year now, with no problems. While I can't prove any performance increase, I have noticed an improved throttle response, nut the main reason I've kept it, it's reusable /ubbthreads/images/graemlins/smirk.gif
  28. toasty
    toasty Member
    52
    True, but the A3 i.8T doesn't have a MAF so you wouldn't have the oil and worries.
    I think the 1.8T engines have a pressure sensor, not air mass.
  29. Drill
    Drill Member
    928
    Actually, I DO have a MAF, or MAP or whatever /ubbthreads/images/graemlins/crazy.gif Same part (at least externally) as the S3 /ubbthreads/images/graemlins/tongue.gif
  30. Joshie
    Joshie Member
    71
    [ QUOTE ]
    [/ QUOTE ]
    Another TFB /ubbthreads/images/graemlins/grin.gif
    What do you do, wash it in warm soapy water and then apply axle grease /ubbthreads/images/graemlins/laugh.gif
    Seriously though - how is it serviced?
  31. AL_B
    1,670
    82
    Dan,
    Yeah I can confirm Drill's response. Mine (MAF/MAP) got knackered on my A3 1.8T.
    AL
  32. Drill
    Drill Member
    928
    Joshie,
    Actually, K&N have a "Recharger Kit" to clean the filter, it contains cleaner, which you spray on (or soak) the filter with, then you let it dry, and spray on the K&N oil. That's it /ubbthreads/images/graemlins/smirk.gif The only problem with the 1.8T's is if you put too much oil on, you can easily coat your MAF with excess oil, thereby giving it hell. What I do, of course I've only recharged mine 2X now, but I make sure I keep the oil light, and if I do overspray a bit, I blot it with a towel, and pay a bit closer attention to my MAF.
  33. Moresauce
    Moresauce Member
    570
    Booked the car in for a service and had a chat with the dealer about MAF's, basically he said unless you were running an aftermarket filter or driving in seriously dusty condtions there is NO point in this.
  34. RichA3Turbo
    5,089
    So what type of sensor would a 1998 1.8T (a3) have?
    Rich B
  35. Crafty
    Crafty Member
    223
    [ QUOTE ]
    [/ QUOTE ]
    Both. MAF is used for fuelling, MAP is used for boost control.
