Maf cleaned this morning. Is this gap at the side normal.
Vanessa May 11, 2014
  1. Vanessa
    Vanessa Member
    98
    20
    I cleaned my maf this morning, as car has a stutter and thought it would not harm to clean it. I have never done it before.
    All cleaned but when I put it back together I noticed a gap at the side, is this normal.
    Also I used electrical contact cleaner, do I need to leave it for a certain length of time before I use the car again. I.e drying time for the contact cleaner.
  2. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,208
    389
    That hole will be sucking in un-metered air.
    Yeah leave it to dry although it does evaporate quickly
  3. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    That hole in the side looks well wrong. Like it's been fitted with the wrong MAF or housing you unscrewed.
    The hole needs to be sealed to avoid false readings by MAF.
    Use something like araldite.. i.e a hard setting compound.
  4. XFi
    XFi In need of a V8.
    491
    47
    Is that the airbox which it is attached to? If it is then it won't be giving a false air reading but it will be unfiltered air, which is not ideal.
  5. max69vk
    max69vk Active Member
    862
    57
    There should be a short pipe attached to where the MAF is currently fitted, the MAF then screws to the pipe.
  6. Vanessa
    Vanessa Member
    98
    20
    Thanks for all the info. How can I tell if it's the wrong maf, does it have a specific part number. I am wondering if this is what is causing the stuttering at 50km hr, I am getting every time I set off. It clears after 20 seconds or so. Could the air gap be causing thei, if it should not be there.
