MAF causing ABS/ESP warning + hesitation
Adam_S3 Nov 20, 2013
  1. Adam_S3
    Adam_S3 Member
    45
    Hi all,
    I've been experiencing some hesitation and bogging down under load from my s3 since i got it 3 weeks ago. In conjuction with this i have had intermittantly the abs and esp lights coming on the dashboard.
    Yesterday aswell as the lights i got the warning display and 3 beeps flashing on the dash "ABS fault go to dealer"... then today leaving work the car seemed to go into limp mode and i had no power.
    I decided to try unplugging the MAF to see if it would fix the hesitating - and it did! completely different car.
    The question is, a bit of research has shown me that the MAF frequently triggers the ABS/ESP due to them reading it for load data... What is the chances of me replacing the MAF and solving all my problems?
    and also where to buy a new MAF, as i see a lot of people have had issues with ECP recon units.
    Cheers!
  2. cammage08
    cammage08 Member
    171
    10
    Yep, I think you've answered your own question! New maf should do the trick...
  3. epox
    epox Active Member
    773
    74
    you may have read only get a bosch maf from gsf or tps, i got one from ecp and still having issues may not be the maf but.
    mark
  4. Adam_S3
    Adam_S3 Member
    45
    the gsf one is only £45 ... so unsure if that's a bit cheap to be a good 'un?
  5. rupe
    rupe A3 TQS In Devon
    255
    35
    I should think the bosch one will be the premium part, which works out about £80 ish after you get the surcharge back.
  6. Adam_S3
    Adam_S3 Member
    45
    Fitted the nww MAF today... hesitation sorted. ABS Warning and 3 beeps still going... I tried disconnecting the battery but that didn't work..
    And still no fault codes (scanning with torque app and obd2 bluetooth)
    Any ideas?
  7. badger5
    9,511
    2,004
    3 beeps low brake fluid?
  8. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,267
    596
    Torque App is no good, only reads OBDII related codes, not Manufacture specific which is what you need.
    Rick
  9. Adam_S3
    Adam_S3 Member
    45
    3 beeps abs fault take car to workshop...
