MAF / Airflow / Running problems
SimonA4 Jul 11, 2004
  1. SimonA4
    SimonA4 New Member
    Whilst trying to trace the poor running of my recently acquired A4, and following the links suggested on this site (thanks guys!) I've found several mentions of the MASS AIRFLOW SENSOR. It sounds like a possible culprit and seems to be somewhere around the air outlet housings.
    So I had a check under the bonnet and found something not right - a pipe that connects from the back of the rocker cover to the large air outlet pipe at the back of the engine was broken in half! Obviously happened some time ago as it was partially wrapped in insulating tape, which had become caked in oil and slipped off. I took the pipe off, cleaned it and taped it back together as best I could, hoping the running would improve if the possible air leak or pressure drop was temporary fixed. Unfortunately still runs bad.
    Where EXACTLY is the MAF? I just had a horrible sinking feeling that it used to be housed inside that pipe and has fallen out when the tape gave way?
    I know that replacement MAFs are very expensive, so any advice on where it is, how to remove it and check/clean it would be much appreciated.
  2. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,091
    2,540
  3. SimonA4
    SimonA4 New Member
    Sorry - 1995 1.6
  4. ImolaS4
    ImolaS4 Member
    275
    The MAF is the Mass Air Flow sensor. It won't "fall out". It's a piece that is fitted along the plumbing and is the same size as the plumbing. My unit is about 4 inches long and the same diameter as the intake hosing. It is part of the intake plumbing.
