mad max diverter
jezzy Sep 7, 2012
  1. jezzy
    jezzy Member
    768
    so after a lot of reading and research i decided to try the mad max diverter.
    Bought a evo 9 diverter for £60 ebay.
    Turned up, did the fill on the oem hole and drilled the new one.
    Fitted and went for a spin.
    i did not crush the top part yet, im not running huge boost and fitted backwards( reversal of normal dv fitting)
    First thoughts are very impressive.
    Very responsive and good pick up between changes.
    off to work now so i will let you know how it works on a longer run.
  2. dusty
    dusty Active Member Team Nogaro Blue Audi S3
    267
    46
    I need a new d.v. I've been looking at these and the forge 008p let us know how you get on with it
  3. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Have a look on the ttforum, big thread on there on them....
  4. dusty
    267
    46
    Thanks mate I've just read about them what are your opinions should i get the mad max or the forge 008
  5. Dani_B19
    9,380
    402
    Had mine fitted for about 3 weeks and love it, its the actual one off max, noise, response etc is immense, just a shame about the price.
  6. beachbuggy
    1,931
    202
    To be honest I have never used one, for the simple reason it's a DV, it has no performance enhancement, the forge DV's are good and so are 3rd party ones. As long as it holds boost and opens when it should it doesn't matter who or what make it is in my opinion! Buy it if you feel like something different but it's not going to change your life. It's better than stock , which is all that matters!
    But listen to those that have used
  7. Dani_B19
    9,380
    402
    Dan i totally agree but this is a defo improvement over the forge 008 that i ran, throttle response is better and back on boost is better if that makes sense.
  8. beachbuggy
    1,931
    202
    It's funny as its the "BIGGEST" thing on ttforum at the moment but things like Wellys coolers, b5 tips , hybrids all seem to be behind..
    Maybe we're all being a bit slow now with this!
  9. dusty
    267
    46
    I have a bailey valve at the moment was on the car when i got it the threads in the plastic nipple where the small hose goes to are stripped its loose and I would like to replace my valve for this reason
  10. badger5
    9,598
    2,060
    you are talking about the TT forum tho..... lol
    it has to be both cheap, and shiney
  11. jezzy
    jezzy Member
    768
    A little update.
    Last night on the way home, coil pack gave the ghost (was trying the tfsi uprade coils)
    Got home just.
    So this morning refitted my old bolt downs and went to pick up my xs manni gasket (wrong one will have to wait till monday now to fit xs)
    Any way i would recommend this valve, you can feel the difference between gear changes and pick up.
    im glad i took plunge, the valve all in all cost me about £100 with reducers and hose.
    Dani does The hole in your valve go all the way through to the internal chamber? or does it just penetrate the first skin?
    This is the only part i didnt understand
    The valve is double skinned where the hole is
    My valve is deffo not shiney lol
  12. Dani_B19
    9,380
    402
    Sure mine goes all the way through mate, ill double check and let you know. Got any pucs of your setup? I didnt use reducers, i just fitted a 35mm t piece on my coldside dv kit and Used a 35mm elbow onto the t for opitmal flow lol.
  13. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    Ya got pics dan won't mind one ha is it louder than the 007p and feel better or u not had one pal
  14. Dani_B19
    9,380
    402
    Ill post aome up tomorrow pal, its massive at side of the 008, and yeah i e got one, the soind is awesome compared to the forge ones, nice little flutter chcked in too.
  15. jezzy
    jezzy Member
    768
    Thanks dani
    Will drill all the way through then. and crush the top.
    Will do picks on monday mate (cars in bits a mo, xs mani being fitted)
  16. Dani_B19
    9,380
    402
    Yeah sure it needs drilling all the way, also dont crush the top
    too
    much, only needs doing a littlw.
  17. Snash7
    Snash7 Member
    84
    Where would i find one of these mad max dv's and would thry suit a non mapped a3 1.8t
    Cheers grant
