Mac or Dell PC for business use
TDI-line Aug 27, 2008
  1. TDI-line
    TDI-line Uber Post Whore Team Floret Silver quattro Audi A3 Black Edition TDi
    9,469
    1,055
    Hi guys,
    i'm just after some advice on the following..
    I am setting up a heating and plumbing company, so will be mobile based, i have signed up to BT ring central so i can have a uniformed 0844 number and this can also route any numbers and acts a fax too.
    BT ring central is not MAC based yet.
    http://www.ringcentral.bt.com/fax
    I also will be using SAGE, as my accountant uses this, and it simplifies things. Again, not MAC based.
    I would love the new IMAC, but then would i have to buy a copy of an OS of Windows, and a parallel running program for the MAC.
    Or do i make things simple and get another decent specced Dell PC which will run these things.
    At present i have a MacBook Pro for my own use, and a 4 year old Dell.
    Also what's all this Intel Quad core stuff?
  2. Geordie Mike
    Geordie Mike Yeee-haw
    520
    Are you going to be exchanging a lot of data with suppliers etc? Will this be .pdf, or are there some specific applications you could think of using? If you're going to be dealing with others then I'd stick with dell just as the interfacing is far easier. If you're stand alone then all the computers are realistically far overspecced for what you really need, so go for what you really want.
  3. Kontraband
    Kontraband Active Member
    2,000
    Id stick with the dell too unless you were doing summat mac specific... and by the sounds of it you are doing the opposite.
  4. rickparmar
    rickparmar va va voom
    2,272
    Am a mac user to, but when it comes to businesses your best bet is to use windows on a pc,
    even tho you can put windows on a mac not everything will run it the way you want with 3rd part applications.
  5. Nilz
    11,300
    859
    I would stick with the Dell, just for ease of use and compatability with other business associates, also from a support point of view, i would say you would most probably be able to get alot more Windows support than Mac.
  6. marriedblonde
    marriedblonde Active Member
    4,371
    Personally I would stick with Dell alos. MAC's are great but for normal office/company work the Dell will be the better bet and cheaper...
  7. TDI-line
    9,469
    1,055
    5 out of 5, thanks guys.
    Think i'll order a hardcore Dell XPS then.
  8. TDI-line
    9,469
    1,055
    Oh, is there any reason to get a blu-ray driver other than to watch BR films on the pc?
  9. abdus
    abdus Top Gear VCDS Map User
    1,827
    blu-ray driver will read blu ray discs.
    you might need a blu ray writer which will enable more storage on blu ray discs
    go for a quad core :)
  10. TDI-line
    9,469
    1,055
    Thanks Abdus.
    Looking at a very high spec Dell 420 XPS, with quad cord processor Q9400 2.6ghz, 1333mhz and Graphics 1GB ATI Radeon 3870 X2 graphics card. Hopefully will be ok.
    Also found a discount promotion on-line, so can save 10%. He he.
  11. abdus
    1,827
    try this code at checkout (dell website):
    W2N3KTH5ZLW3M8
    not sure when it expires though. It's a 10% discount coupon
  12. TDI-line
    9,469
    1,055
    Ok, if mine doesn't work then i'll give it a go.
