m8s new car coding probelms
tdi-man Dec 5, 2013
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    m8s just got A3 sline but think the rnse hasn't been coded propely any advice or help please
    thanks
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 7D
    VIN: WAUZZZ8P85A037119 Mileage: 171440km/106527miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Not registered 0011
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 DT HW: 028 101 189 2
    Component: R4 2,0L EDC 0000AG 5878
    Revision: 12345678 Serial number: AUX7Z0D7FNB08P
    Coding: 0000078
    Shop #: WSC 06435 000 00000
    VCID: 78FBECD37243
    3 Faults Found:
    16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    P0118 - 000 - -
    Freeze Frame:
    RPM: 756 /min
    Torque: 66.0 Nm
    Speed: 10.0 km/h
    Load: 0.0 %
    Voltage: 13.45 V
    Bin. Bits: 11000011
    Temperature: 30.6°C
    Temperature: 51.3°C
    17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
    P0671 - 000 - -
    Freeze Frame:
    RPM: 0 /min
    Torque: 188.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.86 V
    Bin. Bits: 11000100
    Temperature: 2.7°C
    Bin. Bits: 00110000
    16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
    P0234 - 000 - -
    Freeze Frame:
    RPM: 2646 /min
    Torque: 232.0 Nm
    Speed: 80.0 km/h
    Load: 65.5 %
    Voltage: 14.14 V
    Bin. Bits: 11000000
    Absolute Pres.: 2050.2 mbar
    Absolute Pres.: 2590.8 mbar
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 041 N HW: 02E 927 770 AD
    Component: GSG DSG 041 0813
    Revision: 00004010 Serial number: 00000407230354
    Coding: 0000020
    VCID: 1D35DD47BD21
    No fault code found.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    VCID: 3A7F36DB0CCF
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 F HW: 8P0 820 043 F
    Component: KlimavollautomatH12 0150
    Revision: 010497 Serial number: 8P0820043F
    Shop #: WSC 00000 000 00000
    VCID: 2F69178FC78D
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H30 0501
    Revision: 00030000 Serial number: 00000000984721
    Coding: 05884F00A2141000000000000000000000
    VCID: 3B7133DF03F5
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 00000
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0011602
    VCID: 43814B3F7B05
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 HW: 8P0 953 549
    Component: Lenksäulenmodul H11 0020
    Coding: 0011112
    VCID: FBF173DFC375
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H03 0040
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 P HW: 8P0 920 980 P
    Component: KOMBIINSTR. VDO H71 0210
    Revision: D03 Serial number: 2247DD03004049
    Coding: 0000408
    Shop #: WSC 00006 067 57207
    VCID: 448348237E0B
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500104729095D
    Coding: 3F0F0B42070101
    VCID: 285BFC93E263
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 254
    Reset counter: 176
    Mileage: 82657 km
    Time Indication: 0
    Date: 2009.02.16
    Time: 11:50:12
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D03 Serial number: AUX7Z0D7FNB08P
    VCID: 448348237E0B
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 Q HW: 8P0 035 192 Q
    Component: RNS-E HIGH EU H75 0650
    Revision: 06S Serial number: AUZBZ7H0906264
    Coding: 0209753
    Shop #: WSC 47155 124 09050
    VCID: 3D753DC71DE1
    5 Faults Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Reset counter: 176
    Mileage: 109004 km
    Time Indication: 0
    Date: 2010.06.22
    Time: 17:01:27
    Freeze Frame:
    Mileage: 171420 km
    Count: 412
    Clock: 18:31
    00857 - CD Changer Unit (R41)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 164647 km
    Time Indication: 0
    Date: 2013.08.03
    Time: 13:47:28
    16352 - Control Module - Electrical Error
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 84
    Mileage: 127891 km
    Time Indication: 0
    Date: 2011.09.19
    Time: 13:23:07
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 109004 km
    Time Indication: 0
    Date: 2010.06.22
    Time: 17:01:28
    02005 - Coding Pin
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 109004 km
    Time Indication: 0
    Date: 2010.06.22
    Time: 17:01:27
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000120
    VCID: 3D753DC71DE1
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.10 1301
    VCID: 306B14F3DAB3
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 008000186D288505489AC63000
    VCID: F9FD69D7C949
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 003 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH25 0160
    Revision: 00003 Serial number: 10000001129133
    VCID: F0EB54F39A33
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 E
    Coding: 0000120
    VCID: 3E773ACB10E7
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209753
    VCID: 3D753DC71DE1
    5 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 176
    Mileage: 109004 km
    Time Indication: 0
    Date: 2010.06.22
    Time: 17:01:27
    Freeze Frame:
    Mileage: 171420 km
    Count: 412
    Clock: 18:31
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 164647 km
    Time Indication: 0
    Date: 2013.08.03
    Time: 13:47:28
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 84
    Mileage: 127891 km
    Time Indication: 0
    Date: 2011.09.19
    Time: 13:23:07
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 109004 km
    Time Indication: 0
    Date: 2010.06.22
    Time: 17:01:28
    02005 - Coding Pin
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 198
    Mileage: 109004 km
    Time Indication: 0
    Date: 2010.06.22
    Time: 17:01:27
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D550D87CD81
    End ---------------------------------------------------------------------
