Luggage cover. . .
Avo Jul 13, 2011
  1. Avo
    Avo Ex-pat
    35
    Guys, once again I am bowing to the proffesionality and expertise of the members of Audi sport for help. I have a 2004 A4 1.8T (163) Avant, the problem is with the luggage cover. At the slightest bump on the road the cover opens, I've taken a look at it andnotjing jumps out at me, just as a trial I wrapped the lugs in a layerof Black electricians tape invade they wereworn and thisis the problem but items still happening. . .
    Anyone else had the same or similar ?
  2. dope
    dope alcoholic pervert
    199
    Yep I have the same issue. Makes you jump doesn't it?!
  3. swarcup
    swarcup Well-Known Member
    1,326
    40
    there was a thread i read on here a while age that gave a solution to the issue if you can turn it up it may be useful
  4. scott b
    scott b Active Member VCDS Map User
    1,254
    i think ppl use heat shrink on the locating pegs to make it a tight fit
  5. Avo
    Avo Ex-pat
    35
    Cheers I'll see if I can locate the thread . . And yup it puts the willies up ya, especially driving around Northern Ireland and then a bang lol
  6. T0m
    T0m Active Member
    516
    26
    Mines the same driving me nuts just recently!!!
  7. Grangey.
    Grangey. Member
    226
    so thats what that is!!!
    If someone finds the thread with fix please post it
  8. dope
    199
    Found this on Audizine
    Cargo Cover keeps popping loose
    Seems some strips of the soft fuzzy part of stick-on velcro do the trick.
    Clearly it's a problem scaring the crapola out of avant drivers the world over...
  9. quattrojames
    14,050
    578
    Mines *never* done it ....!
  10. dope
    199
    It will do James. It's just building up the suspense.
  11. quattrojames
    14,050
    578
    Gonna be hell of a bang after 4 and a half years!
  12. chrisash32
    chrisash32 Member
    573
    mine used to do it when i first got the car.
    Fixed it by wrapping a bit of that fabric electrical tape that Audi use around the lugs on the end.
  13. Mrmok
    Mrmok Member
    60
    Mine does the same all the time so I just leave it off now......usually either got a pram or a german shepherd in the boot anyway so couldn't use it if I wanted to
  14. Avo
    Avo Ex-pat
    35
    Some ideas to ponder there, I've searched the forum and found a few threads but all missing solutions. . Anyway off to try a few ideas out. . Cheers again
  15. dope
    199
    Wrapped some of the stick fuzzy velcro round the lugs last night. Seems to have done the trick.
  16. Widemonkeys
    Widemonkeys 1st Gear
    271
    Mines never done it either but it does make an awful squeaking noise when I go over bumps
  17. JimLoskot
    JimLoskot Member
    161
    there are 2 main solutions, either put some heat wrap around the pegs or get some plastic inserts to put in the locators. I've done the later, they are about £7 from TPS. I'll see if I can find the thread
  18. JimLoskot
    JimLoskot Member
    161
  19. swarcup
    1,326
    40
    Thats the fella. an actual proper fix from audi
  20. Mrmok
    Mrmok Member
    60
    Mine used to do that too until I sprayed with WD40! Instant fix :)
  21. Widemonkeys
    271
    Where abouts did u spray it, cos I've looked and can't see any mechanical parts
  22. T0m
    T0m Active Member
    516
    26
    Thanks for the post Ive ordered a kit from Audi costs £10!!!
  23. blacktar
    blacktar New Member
    12
    hi what came in the kit was it 1 or the 2 bits
    cheers
