  1. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Hello gents, just a quick one this time.....Is water a sufficient lube for claying? I usually use a quick detailer but annoys me as its a waste of money as I will use a whole bottle of it when doing the whole of my car. Be great to hear your opinions!
    Ollie
  2. jay1601
    jay1601 Well-Known Member
    1,344
    73
    rinse
    wash (2 buckets)
    rinse and while the car is still wet use detailer and clay. i find only use 1/4 the amount compared to dry
    then rinse
    megs step 1
    megs step 2
    chemical guys XXX hardcore paste wax
    thats how i do mine :)
  3. phoenixv6quattro
    1,396
    I'de rather not use any QD as lube. Rather leave the car wet and spray water on via a bottle. Need to know if this will suffice. Not a fan of the Megs range. Got blackfire on at the mo.
  4. 1210tech
    1210tech Four Ring Fanatic Team Daytona Team V6 Audi A6 Audi Avant Owner Group S-line owners group
    696
    If you really don't want to use a detail spray then you can get away with making up a weak mix of wash shampoo with water in a spray bottle.
    You do need to use some kind of solution to act as a lubricant rather than just water to help the clay bar slide freely over the surface
  5. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,163
    1,123
    I've all ways used water when claying, never noticed any issues or damage to the paint work.
    The only difference I noticed between water and QD is the smell.
    Is there more to it than just the smell?
    EDIT:=- Added missing words.
  6. phoenixv6quattro
    1,396
    Excellent! Will try it in the spring!
  7. A4SLineJC
    A4SLineJC Member
    67
    Weak shampoo mix or use bilt hamber clay, excellent value plus you can use it with water only as a lube!!
