Lowering
bar Dec 24, 2009
  1. bar
    bar New Member
    9
    hi can some1 posibly tell me where i can get some 60mm lowering springs for a a.3 1.6 sport 1998.tried ebay but cant seem to locate any
    help apreciated
  2. jojo
    28,929
    3,583
    Damian from DPM should be on here soon to help out! :)
  3. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    most spring kits go about 40mm you might need coil overs to go to 60mm
  4. bar
    bar New Member
    9
    yea i was wandaring that.40mm just dont look the part tho does it i dont think anyway
  5. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Budget for new drop links and anti roll bars. You cant just lob -60mm springs on an A3. If you do your ARB will rub on your drive shaft.
  6. bar
    bar New Member
    9
    what would you say best way to go then dude?defo want to bring it down more then 40mm
  7. A3Tom
    3,504
    14
    Drop it as low as you want to but just be aware its not as easy as just slapping some spring in there.
    If you want to go -60mm then you can do it on springs..just budget for a new front antiroll bar so it clears the driveshaft.
  8. DPM
    DPM Site Sponsor Site Sponsor
    5,032
    207
    As mentioned anything beyond 50mm and you'll need either new adjustable drop links or an up rated front ARB, to get -60mm you'll need coilovers though.
    Did you have a budget in mind?
    Damian @ DPM Performance
  9. dan1973
    dan1973 OCD clean
    301
    Damien you have a pm mate
  10. glossy555
    glossy555 Member
    49
    my a4 is lowered 50mm... makes a big difference what size wheels they are too. they 18" or 19"??
    but i was told when buyin the springs an a4 will go to 50mm but mightn't compress enough for 60mm lower. not sure if this relates to the a3 too but they're probably around the same.
  11. bar
    bar New Member
    9
    ive got 16s on at the m.o.just want to get that low fat look without to much dents to the wallet but will defo look in too a coilover kit now thanks everyone
