Lowering Springs HELP!!!! FITTING!!
johnnysalv Apr 28, 2010
  1. johnnysalv
    johnnysalv A3
    29
    Help want to fit my lowering spring to the rear of my A3 2005 plate. Whats the best way to fit?????
    Do the rear wheels need to come of? Do I need any special tools just for the rears???
    Cheers Johnny
  2. smudge_don
    smudge_don Active Member
    2,944
    Hi Johnny
    Very simple, ideally take the wheels off yes and grab yourself some axel stands
    Jack the car up, stick the stands underneath so that they are holding the chasis up, not the rear axle
    The hubs will drop down and you can take the springs out with a bit of elbow grease
    Then a case of shoving the new springs in place, and you're done
  3. johnnysalv
    johnnysalv A3
    29
    How many bolts, do I have been told just to remove the bolt for the shock as its the only thing holding the springin that correct or not?
  4. smudge_don
    2,944
    Rear spring and rear shock are different bits mate
    Not like the front where the spring goes over the shock
  5. bambam
    bambam Member
    123
    Are there any guides available for changing the front springs?
    mainly the shock/hub interface and any tips that make the whole job easier!!
    TIA
  6. Stampie
    Stampie Member
    105
    Typical! I have just done mine a thought I'd do a pic guide to changing them - Fronts were such a pain in the arse I gave up with the guide!!!
    STampies tips....
    1 = 2 people (pref male with muscles!)
    2 = Spring compressors
    3 = Ring spanner for removing top nut on fronts - Mine needed 21mm
    4 = Spline sockets - need one for the fronts, although I gently persuaded a Torx socket to fit!
  7. cooltempo
    cooltempo Heavy DERV clatter
    95
    im thinking of doing this too, my neighbour has two gas lifts in his garage and loads of tools, so hopefully be ok?
    just wondering why were the fronts so difficult? just awkward angles?
  8. vw754
    vw754 vorsprung Durch Technik
    2,329
    58
    ive done mine,took out complete hub,disconnected driveshaft,link arm not too bad of a job
  9. NY_Sportback
    NY_Sportback Member
    58
    check this link as the MKV Jetta and GTI use the same suspension design as our cars, I've done the rears in less then an hour and most of that time is jacking the car up and removing the wheels:icon_thumright:
    http://www.swankmonkey.com/vw/jetta/2006/suspension/
  10. cooltempo
    95
    Thanks NY_Sportback ;) can anyone who has done this confirm that this guide would work with the A3?
  11. Phatboyruss1
    Phatboyruss1 Member
    75
    Just a quick question before I get ordering :eyebrows: I've got an A3 Tdi Sport (53) running 235/35/19's wheels and tyres. I want to lower the car (on springs as its my daily driver and I want to retain some sort of comfort, those tyres can be hard!!)
    I was looking at Eibach springs, which is the best option for me the pro or the sportline kit? has anyone had experience/can recommend with other spring makes?
    Cheers in advance.
  12. gingers3
    gingers3 Active Member
    678
    119
    43
    i think H&R s are better i think eibach only lower the front !
