Lowering springs for a B7 saloon
astradti16v Sep 4, 2012
  1. astradti16v
    astradti16v Member
    54
    I am looking to buy a set of lowering springs and have narrowed it down to two sets for my B7 saloon.
    It is either the Eibach or H&R lowering springs. Has anyone got pictures showing the drop with either of these springs?
    Thanks.
  2. Joe_Murphy21187
    Joe_Murphy21187 Tiptronic
    1,021
    67
    Search function if your friend...
    Also it depends if you're looking at the 30mm or 45mm (H&R) or the sportline (I think?) or the other model of Eibach.
    I've got 30mm H&Rs on my A4, but it's not a saloon so probably of no use to you. The 45mm H&R springs make it sit as it should've done from the factory.
  3. DPM
    DPM Site Sponsor Site Sponsor
    4,917
    179
    What engine is it and is it FWD or Quattro?
    Damian @ DPM Performance
  4. astradti16v
    astradti16v Member
    54
    Its a fwd 2.0 Tdi Sline. Sorry I should have mentioned im looking at the 45mm H&R kit or the Eibach sportlines..
  5. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    438
    Go H&R better drop stance in my opinion you should get it to 40-45 mill just right
  6. davsa4
    davsa4 Member
    257
    19
    eibach sportsline with 19 rotor alloys and 10mm spacers on rear, no issues
  7. Joe_Murphy21187
    1,021
    67
  8. DPM
    4,917
    179
    Personally I'd go for the Sportlines, I find the stance better.
  9. astradti16v
    astradti16v Member
    54
    Your car looks awesome. Have you got a pic from side on by any chance?
  10. steve123a
    steve123a Member
    240
  11. davsa4
    davsa4 Member
    257
    19
    this is nearest i have of a side on shot
    steve123a likes this.
  12. astradti16v
    astradti16v Member
    54
    That sits very well.
  13. mattjarv
    mattjarv Member
    75
    Where did you get those Rotor wheels from? I have a grey Cab and think they'd look good on mine, too.
  14. Tiffy
    Tiffy Active Member
    363
    89
    I have Eibach Sportlines on my Avant and the ride is superb, ALOT better than the standard S-Line set up....
  15. Avnt
    Avnt Active Member
    240
    25
    What do you use to keep it shining?
  16. Olly P
    Olly P My other cars a mk2 Golf GTi
    700
    12
    Some good pics there! Is it just me or does the front sit slightly higher on both the H&R 45mm and Eibach Sportlines? I've just bought a set of H&R 45mm to replace a broken set of FK coilovers, i'm in two minds wether to get a B5 perch plate too?
  17. Beni786
    Beni786 Member
    69
    I'm in the same boat, can't decide which ones to go for, and more importantly how much to drop it, 30, 40, 45, 50?????
  18. Biddyy
    Biddyy Member
    40
    Depends if ur quattro and s-line as they are different again, neither do 40/50 lowering springs for the quattro, just 30 is it (all i can find), same with s-line. the 40/50's are for non sline/quattro cars. this is probably as it's 25 lower already..
    Coilovers your option if you want lower.
  19. Fast3000
    Fast3000 Member
    103
    Good post guys.
    What shocks would you get with the sportline suspension?
  20. ajax1976
    ajax1976 Well-Known Member
    1,253
    648
    35mm H&Rs are only for FWD cars, 45mm for Quattros.
    I have 35mm H&Rs on standard S Line shocks.
    CHEZ likes this.
  21. CHEZ
    CHEZ moderately amusing Supporter
    4,142
    816
  22. ricostuart
    ricostuart Active Member
    409
    43
    there is a deal on here for tein super street for just over £500 from jbs auto designs.
  23. TOM.S
    TOM.S Active Member Silver Supporter
    551
    110
    43
    another question in here
    would either eibach sportline / H&R springs be fine with stock Shocks?
    on a S-line quattro
  24. Steve220
    Steve220 Member
    234
    15
    They're all fine with stock shocks.
    TOM.S likes this.
  25. psychopomp1
    psychopomp1 Member
    158
    14
    Hi
    Will be upgrading to 18" wheels from my 16" ones shortly on my 2005 B7 SE (aka poverty spec). Will be getting H&R springs, but should i lower this by 35mm or 45mm? Fancy the latter but want to be 100% sure won't have any issues by going 45mm lower. Also this H&R springs set is only 160 euros (+ 10 euro delivery) from germany, but does anyone know if its the 35mm or 45 mm set?
    H&R Fahrwerksatz, Federn 29368-2
    Cheers :)
  26. ajax1976
    1,253
    648
    H&r do 35mm for Fwd cars and 45mm for 4wd cars, check their website.
  27. ajax1976
    1,253
    648
    They are 45mm springs for 6 cylinder quattros, If your car is FWD and not 6 cylinder you need 29369-1.
    Cheapest I could find when I got mine were Larkspeed.com, £152
  28. psychopomp1
    psychopomp1 Member
    158
    14
  29. Fast3000
    Fast3000 Member
    103
    S Line suspension IMO is probably not the most comfortable....and my car on 65K could do with a refresher on the ride handling....
    Any recommendations on a shock / spring setup?
  30. psychopomp1
    psychopomp1 Member
    158
    14
    Can someone pls confirm that these H&R springs will be ok for my 05 plate B7 saloon (FWD)?
    H&R Fahrwerksatz, Federn 29369-1
    Also my local VAG indy garage is charging £300+vat to get them fitted, is this a fair price?
  31. Furkz
    Furkz Active Member
    303
  32. ajax1976
    1,253
    648
    I already said you need 29369-1, do you not trust me:laugh:. Google the number or check on the H&R website!!
    Does seem a bit steep, they can be a bit of a PITA and time consuming, maybe the garage has done and struggled with plenty before!! I wouldn't pay that tho, I'd be thinking more 150-200.
    psychopomp1 likes this.
