Lowering Springs for a Audi 1.6 need help!!!!!
I oOEddOo I Mar 21, 2010
  1. I oOEddOo I
    I oOEddOo I Member
    340
    15
    I want to lower the car so the back wheel is like sticking out but i need to know if 30mm is enough also i would prefer using eibach springs
  2. RS_Cosworth
    RS_Cosworth Member
    124
    Not sure what you mean matey?? :confused:
  3. I oOEddOo I
    I oOEddOo I Member
    340
    15
    so it makes the wheel look wider if that make sense .....
    but would 30mm enough using eibach pro springs that is the question
    do you have any other brands is similar ??
  4. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Wheel spacers is what you need if you are looking for a wider track
    Suspension will do diddly to that.
  5. I oOEddOo I
    I oOEddOo I Member
    340
    15
    where can you get a wheel spacers and good price
  6. DPM
    DPM Site Sponsor Site Sponsor
    5,016
    206
    As mentioned, springs make the car look lower but if you want your wheels further out then it's spacers that you need.
    Damian @ DPM Performance
  7. I oOEddOo I
    I oOEddOo I Member
    340
    15
    I also want to know if lowering 30mm is enough to look sporty using eibach pro ??
    any other good suggestion ??
  8. DPM
    5,016
    206
    Personal choice really, some like a subtle drop and some want it lower.
  9. I oOEddOo I
    I oOEddOo I Member
    340
    15
    But the 1.6 does look really high lowering 30mm is enough ??
  10. RS_Cosworth
    RS_Cosworth Member
    124
    Like Damian says mate only you can decide, do you want it to look just slightly lower than it is now or alot lower??
  11. PH1L
    PH1L Gievf Buckets
    3,851
    40
    depends if youve got an se sport or an sline each is lower than the previous
  12. I oOEddOo I
    I oOEddOo I Member
    340
    15
    The stanadard version which is not a sport or s.line
    the back end looks abit high just wondering 30mm is enough to bring it down just slightly lower than the s.line version if you know what i mean
  13. PH1L
    PH1L Gievf Buckets
    3,851
    40
    ahh right well sounds like a set of springs and spacers are on teh cards
  14. I oOEddOo I
    I oOEddOo I Member
    340
    15
    Wa springs to go for any suggestion ??
  15. PH1L
    PH1L Gievf Buckets
    3,851
    40
    eibach are always a god choice, as are h&r have a look on the dpm website
  16. I oOEddOo I
    I oOEddOo I Member
    340
    15
    Alot of people sed Eibach pro kit is good but they only lower 30mm
    But Eibach sportline springs can lower front- 45-50mm and rear 35-40mm nt sure if they are as good
  17. PH1L
    PH1L Gievf Buckets
    3,851
    40
    your car will be dropped lower than most as the sport is slightly lower than yours and the sline is lower than that, around 15mm a go i think so you will achive a much larger drop from the springs
  18. I oOEddOo I
    I oOEddOo I Member
    340
    15
    so which one should go for ??
  19. RS_Cosworth
    RS_Cosworth Member
    124
    Just to throw another choice into the mix, I've recently fitted mine with H&R -50mm springs and I think they're absolutely brilliant! They give an excellent quality ride with what I consider to be the perfect drop at both front & rear, I wouldn't hesitate in recommending them to anybody :icon_thumright:
  20. RS_Cosworth
    RS_Cosworth Member
    124
  21. I oOEddOo I
    I oOEddOo I Member
    340
    15
    RS_Cosworth
    neutral
    Is it 50mm in front and the rear also 50mm ??
    H&R is for (audi 8L) does it still suit (audi 8P)??
  22. RS_Cosworth
    RS_Cosworth Member
    124
    They lower both the front & rear 50mm, and they're available for 8L and 8P models mate
  23. vw754
    vw754 vorsprung Durch Technik
    2,334
    58
  24. I oOEddOo I
    I oOEddOo I Member
    340
    15
    RS Cosworth
    Can you send me website for it please mate that will be very helpful
    thank you
  25. RS_Cosworth
    RS_Cosworth Member
    124
  26. scottie123
    1,972
  27. I oOEddOo I
    I oOEddOo I Member
    340
    15
    Now i hearing a few saying H&R is good ??
    H&R or Eibach ??
  28. RS_Cosworth
    RS_Cosworth Member
    124
    You can't go wrong with either tbh mate, but very good makes. All I can say though is I have H&R's fitted to mine and imo they're pretty much as perfect as you're gonna get!
  29. I oOEddOo I
    I oOEddOo I Member
    340
    15
    Eibach seems cheaper for lowering 45-50mm in front and back 35-40mm
    H&R is bit expensive
  30. PH1L
    PH1L Gievf Buckets
    3,851
    40
    then go eibach both brands have good followings
  31. I oOEddOo I
    I oOEddOo I Member
    340
    15
    yh i might go for the eibach sportline one
    does anyone know if they are good or similar to the pro kit ??
  32. PH1L
    PH1L Gievf Buckets
    3,851
    40
    with the 1.6 the only difference you will notice is on looks tbh both will handle well
  33. I oOEddOo I
    I oOEddOo I Member
    340
    15
    Yh eibach looks ok actully just seen that guy lowerd 50mm using eibach
