Lowering a quattro ?
Lowridingaudi Jun 26, 2008
  1. Lowridingaudi
    Lowridingaudi Sline
    I have not lowered a quattro before, is there anything I need to be aware of?
    I have a B7 A4 2.0TFSI Sline quattro and the time has come for it sit lower to the ground-
    I have ordered a set of KW V1's
    I have heard that the rear camber needs adjusting...is this true ?
    cheers
  2. DPM
    DPM Site Sponsor Site Sponsor
    5,024
    206
    When ever you lower any car you'll need to adjust the camber at all 4 corners as it'll be out with lowering it.
    Damian @ DPM
  3. Lowridingaudi
    Lowridingaudi Sline
    I know you have to get the tracking re done and camber adjusted but what I wanted to know was do I need to buy any additional parts to allow the camber to be setup correctly like adjustment links?
  4. ultramodz
    ultramodz 06 A4 2.0T FSi S-Line SE
    515
  5. kquattro
    kquattro New Member
    Hi ultramodz
    How much of an improvement are the coilovers over the standard s-line suspension in terms of handling ?
    I am thinking of changing mine to a set of coilovers as I feel the s-line standard suspension has a bit too much roll in it around corners, although its fairly decent over bumps.
    Im wondering if the money would be better spent in uprated anti roll bars instead ?
  6. ultramodz
    515
    I've probably got my coilovers a touch too low to be optimised for handling, but it's definitely an improvement, in terms of body roll reduction & turn-in.
    You may want to consider upgrading to the RS4 rear sway bar, all the details for part numbers, etc are here: http://www.audizine.com/forum/showthread.php?t=105668
    Audizine is a great forum to join - a lot of the guys in the States have already made the majority of performance mods you may be considering & it's great to get their feedback... Not that this one isn't great though!
    Anyway - if you want your car to be firmer & also look purposeful & lowered, coilovers are the way to go.
