lowered... now got epic drive shaft scrappage.... help please
jay1601 May 27, 2011
  1. jay1601
    jay1601 Well-Known Member
    1,311
    57
    fitted my coilovers tuesday. been fine since fitting. must of bedded in today, coming home from work could heard metal on metal.
    checked passage side, its all fine. no marks on shaft
    checked drivers side and its scraping pretty bad
    this is how low it is, not sure how much i went down but its at a high i like
    has anyone else had problems with this, if so what did you do to fix it ?
  2. <tuffty/>
    20,904
    3,713
    Yep, common problem and a search will have highlighted the fix... adjustable drop links for the ARB required bud...
  3. jay1601
    1,311
    57
    i just searched though old threads via google.
    seems like adjustabe drop links don't fix the problem
    needs a new ARB.
  4. <tuffty/>
    20,904
    3,713
    humm... adjustable links have worked for most peeps but maybe yours is lower... Awesome GTI sell them I think...
  5. jay1601
    1,311
    57
    may try new links before spending out £150+ on new ARB
    do you know which links are best to get ?
  6. bhavin1986
    bhavin1986 BBP
    464
    TT ARB with standard droplinks is your answer. It goes under the driveshaft. Can be bought from the dealers for £90 or used for less than £50.
  7. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    LCR ones are the same too incase you scour ebay for a deal.
    Strange how some peoples rub and some peoples don't, ours is super low and it never rubbed. But I know people with cars higher than ours that rubbed.
    Don't buy the cheap ****ty ebay adjustable drop links, they are longer than standard ones and also have very cheap rubber in the bushes so knock after 1000 miles.
  8. jay1601
    1,311
    57
    does it need to be MK1 TT i found a MK2 TT bar for £35 on ebay
  9. <tuffty/>
    20,904
    3,713
  10. audi-tk
    audi-tk Member
    441
    Get a bleeding TT arb lol
  11. jay1601
    1,311
    57
  12. colicabcadam
    colicabcadam Guest
    while you are there, put air n the tyre, it looks proper flat!!!
  13. audi-tk
    audi-tk Member
    441
    U want a Mark 1 Audi TT arb from a quattro . Look on eBay . Put in Audi TT breaking then message them all saying TT arb posted? But always put "how much for a undamaged excellent condition front arb from this mk1 Audi TT quattro with a price posted to..."
  14. jay1601
    1,311
    57
    found a LCR ARB on ebay. can someone confirm it will do the same as the TT one before i buy it
    thanks Jay
  15. 16Klappe
    5,795
    1,183
    Yes.
    Buy it.
  16. 16Klappe
    5,795
    1,183
    Those ones are complete and utter turd Paul, they are the ones we fitted and then threw in the bin.
    The rubber is so weak that after a couple of thousand miles they knock and bang, they are not shorter than the standard links when you have them at their shortest with the lock nut fitted too. We had to remove the locking nut to make them shorter than the standard ones.
    Our car is a few MM's higher than Prawns (IE far too low for Bills rollers!) and it doesn't rub with stock links.
  17. <tuffty/>
    20,904
    3,713
    Thats the solution then... raise the ride height :)
    Can't say I have personal experience of these ones in particular (or any tbh as the S3 uses a different setup)... I am sure there are others more suitable out there... rose jointed ones maybe?
    ...or just bigger wheels and raise the height to something more sump and driveshaft friendly :thumbsup:
  18. jay1601
    1,311
    57
    can't find any on ebay.
    my local scrappy has 1 quattro TT in, they want £75 for it. is that a good price ?
  19. 16Klappe
    5,795
    1,183
    Thats tres expensive, after a bit of main dealer discount I'd expect a new one for that!
  20. jay1601
    1,311
    57
    does anyone have the TT or LCR part number. will phone up see how much it will cost for a new one
  21. a3rob
    a3rob Member
    165
    My a3 is slammed on 18s. Eibach anti roll bar and new drop links. Sweeeeeeeet :)
  22. jay1601
    1,311
    57
    went to audi today. got the new roll bar cost £80.47 the product number is 1J0 411 305 AE incase anyone else needs the number for the correct parts.
    it fits fine with the standard bushes only thing i have got is the linkages are a bit of a weird angle but they are working fine
    i get no rubbing and i'm now slammed on 16's
