lowered my a5,,,,,,,,,,???????????
vw754 Sep 3, 2017
  1. vw754
    vw754 vorsprung Durch Technik
    2,346
    58
    ive lowered on coilovers........measured from edge of fender to middle of wheel center cap..........as stated in this guide http://bd8ba3c866c8cbc330ab-7b26c6f3...horizontal.pdf
    front left and right + rear right are 100% same level.......rear left is a bit lower and i mean a teeny bit id say about 2-3mm (at a guess)
    what i did notice was the perch on the rear left has been adjusted more than the rear right but still sits 2-3mm lower.
    is this normal ?
    also both rears are a pain to adjust as when i tried to adjust both the collars and perches were turning instead of just the collars.
    thought it be a lot easier.
    now i have noticed when im coming off a speed hump(only when im coming off) rear left has a noise, can only describe it as if a bolt is loose,but nothing is....
    i only removed shocker and spring with clamps nothing else on the rear as the guide says above because i found different instructions on another site.
    ALSO WHEN I TRIED ADJUSTING REAR ...I TURN PERCHES AND SLEEVES TURN TOO....BUT ARE FITTED CORRECTLY....SO WHY ?????????
