Lowered front end pic
unikarl Dec 13, 2010
  1. unikarl
    unikarl Member
    367
    As the title says. I fitted the B5 front suspension cups to bring the front end down and get it more level with the back.
    Let me know what we think!
  2. Triple.O.G
    Triple.O.G Active Member
    1,113
    looks good mate, they B8 s-lines? 19?
  3. unikarl
    unikarl Member
    367
    Cheers mate,
    They are 19", just reps. Got some spacers for them to go on tomorrow so should look a bit better then.
  4. Triple.O.G
    1,113
    What spacers? what offsets you running? i should be getting my wheels tomorrow hopefully, et35 but might put spacers on aswell?
  5. unikarl
    unikarl Member
    367
    10mm for the rears and 6mm for the fronts. The wheels are et45 so I reckon your et35's will look spot on without spacers anyway.
  6. MK2 Golf 24v
    MK2 Golf 24v Member
    47
    Any pics of the new and old parts side by side?
    Part numbers?
    I've read about this mod, and done a ton of searching, but couldnt find any real info on it.
  7. Triple.O.G
    1,113
    Check Audizine, they all do it, its just the rubber perches that the spring sits on i believe but the B5 ones are shorter than B7 so you get abit of drop.
    Your dealer will know which parts you need.
  8. unikarl
    unikarl Member
    367
    The part number is 8D0 412 103 B
    They are not the rubber perches. Its the actual metal cup that the spring sits on, your old one slides off the shocker then this new one slides back on in its place. I got mine from Audi and they cost £17.63 each so £35.26 + VAT.
  9. Triple.O.G
    1,113
    I thought there were?
    Will these be ok for aftermarket springs and shocks then? i presume not but the yanks use them with coilovers?
    Maybe iv confused myself?
  10. unikarl
    unikarl Member
    367
    Its defo the metal cups (unless I ordered the wrong part but it worked anyway!!).
    They should work with lowering springs as they are the same height as standard springs out of the box, its just when they are comressed that the car goes further down.....I think!
  11. Bigman
    Bigman Cornish and Proud!
    85
    That looks good, I fitted my B5 spring seats about 4 months ago, made the car look WAY better in my oppinion!
    Adam
  12. unikarl
    unikarl Member
    367
    Thanks for the heads up on this mod mate. I don't know if its my imagination but I'm sure the car rides nicer with them on too!
  13. Triple.O.G
    1,113
    So can i use these with AP springs and shocks? they dont do any for the back do they?
  14. unikarl
    unikarl Member
    367
    You can only do the fronts. It depends on if the shocks are the same dimension as the original Audi ones and the cup slides over it and sits into position on a ridge on the shock. If your AP's are wider it wont go over.
    If you still have your original shocks it might be worth comparing the two.
  15. dubdemand
    dubdemand VAG Addict
    405
    Very tempted to do this myself... Any chance of a brief run down on how to do it?
    Love the car btw - some more pics would be great!!!
  16. unikarl
    unikarl Member
    367
    Sure, here's a run down...(very brief)
    Buy the parts from Audi then run off to your garage like a kid at christmas all excited about making your car look that bit better.
    You have to remove the front shock absorber. Straight forward enough so jack the car up, undo the 3 nuts at the top of the strut that are accesable from under the bonnet, undo the nut and bolt that hold the bottom of the shock absorber onto the lower arm and remove the nut and bolt that hold the upper ball joints onto place. You need to get the ball joints out but that just takes a few carefully positioned taps with the hammer. Once they are out remove the shocker from the car.
    Next you need to take the top mount off the shocker. Use a drop down ring spanner and an allen key. make sure you have fitted a pair of spring compressors for this though. Once thats off, dismantle the rest (it all just pulls off) and then tap the old spring cup off. Place the new spring cup into position and put it all back together. No need for the spring compressors for re fitting.
    If your handy with a spanner then you can have it all done in a couple of hours.
  17. Broken Byzan
    13,235
    464
    Wicked, dont suppose you want to sell me the B6 mounts?
    that will free up a set of B5s if anyone wants them :)
    As i have B6 uprights and the front is too low, how much difference is it in height?
  18. unikarl
    unikarl Member
    367
    Nah, pay the postage and you can have them mate.
  19. dubdemand
    405
    After your B5's if you want to come to some arrangement?
  20. Broken Byzan
    13,235
    464
    I have them off if you need them.
    Karl, have you a picture of the rubber insulators, just for comparison between B5 and B6/7
    The difference from a quick measure is about 15mm, will do the arch to floor measurement tomorrow when i fit the shocks back on.
    So far it's just mounting hole to bottom of mount for comparison, i am aiming to lift mine where as you guys are lowering, but the figures will still stand.
    Currently floor to arch 63.5 cm.
    Mounting hole to bottom of plate ( as best i cam measure) B5 33.4 cm and B6/7 34.8 cm
  21. dubdemand
    405
    Dropped you a PM matey :)
  22. Broken Byzan
    13,235
    464
    any spare b7 insulators kicking around? or pics and measurements by any chance? as the b5 insulators move around a lot
  23. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Unikarl How is the ride now you have fitted these spring perch's. I'm thinking of doing this mod but using a 30mm lowering spring along with the standard oem s-line shock as i have eibach at the moment.
  24. unikarl
    unikarl Member
    367
    The ride is spot on. Its just as it was before. No knocking or banging and just as solid as it was before.
    Its a great little mod.
  25. yorkster001
    yorkster001 Member
    92
    unikarl,
    Where did you source the B5 front suspension cups? They're like rocking horse sh*t!! Considering the mod myself with some 35mm drop H&R springs but can't find the cups.
  26. unikarl
    unikarl Member
    367
    I ordered them from Audi. They arrived next day and were just over £20 for the pair. Bargain!
  27. yorkster001
    yorkster001 Member
    92
    I don't suppose you have a part number? My local dealer seems to have trouble with anything that doesn't coincide with your registration number! It was hard enough getting my DIS mod after been repeatedly told my model doesn't have it fitted!!
  28. Broken Byzan
    13,235
    464
    I have a spare set if needed....
  29. CMD
    3,015
    17
    All Dealer's are the same mate.. My local audi dealer i'm sure has i the word's "it won't fit" Tattooed on his body somewere.
  30. yorkster001
    yorkster001 Member
    92
    PM Sent
  31. jey
    jey Member
    229
    wont need spacers with that offset as it more or less the max to go to to avoid rubbing..
  32. Avant4me
    Avant4me The're Graphite not black!!
    257
    Took a lot of searching to find this thread, defo going to be doing this mod
  33. Avant4me
    257
  34. Mark Shutt
    Mark Shutt New Member
    i would also like to know if the above link is correct for B6 fitment, seams like a good compromise between an expensive lowering kit and a decent enough drop for under £20!
    mark.
  35. Mark Shutt
    did mine today, the parts cost me £15 inc post off ebay, was a pain to do but the 2nd side went much easier once I got the hang of it! the hardest bit for me was connecting the anti roll bar back up, getting the bolt in straight was a nightmare and i ended up taking the bar off to clean the threads up but got there in the end, just have to jack the hub up and twist the link quite hard to get bolt to line up.
    enjoying a beer now and the 15mm drop is spot on for £15!!
  36. CMD
    3,015
    17
    It's a great mod for the price..
  37. PhilW
    PhilW Member
    182
    Awesome for 15 quid!
    Do you have the ebay link you got them from?
  38. Mark Shutt
  39. Mark Shutt
    have noticed if I go over a speed ramp at any speed the front just rubs a little, not too worried but did notice right at the top of the inner arches a big screw/fitting protruding about 5mm so will make these flush fitting as possible.
    anyone else notice this?
    Mark.
  40. unikarl
    unikarl Member
    367
    I dont get any rubbing at all and mine is now coupled with Eibach 50 mil springs too...Weird!
