Lowered car on JOM Coilovers what drop links would be suitable ?
Black Apr 25, 2013
  1. Black
    Black Member
    49
    I have got 2006 Audi 8P and I bought JOM coilies had those fitted, very comfortable although didn't come with drop links, any suggestions it's seems like quite a far distance from coilies to the drop link bar (which ATM bangs on wishbones).
  2. JPK
    JPK Active Member
    303
    FK tuning does adjustable end links and so does whiteline. I have whiteline on my car and they seem to work well.
  3. Black
    Black Member
    49
    Thanks bud, where did you purchase yours ?
  4. JPK
    JPK Active Member
    303
    In NZ. ECS tuning has them or just find a whiteline dealer locally.
  5. TimG
    TimG Active Member
    942
    45
    Hmm. My joms were wound right down and never hit anything! I actually had miles of clearance. Standard drop links too. Strange.
  6. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    What's ride comfort like on these compared to standard setup?
  7. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    606
    34
    do JOMs have helper springs? You may have left yours in and the OP may have removed his.
  8. JPK
    JPK Active Member
    303
    In relation to clearance, i never had a problem with this. I'm not a suspension expert, but I upgraded mine so I could reduce preload on the front sway bar and back within spec after lowering.
  9. TimG
    TimG Active Member
    942
    45
    Good theory but no helpers on joms. Actually i know have fks, with the helpers removed, and im evn lower than i was on joms by a good 30mm and still nothing hits!
  10. Black
    Black Member
    49
  11. TimG
    TimG Active Member
    942
    45
  12. Black
    Black Member
    49
    Ummm, I think it is 35 sits flush with the front arch
  13. TimG
    TimG Active Member
    942
    45
    If its 35 youll defo need a 205, although my guess would be your wheels are 45 in which case a 215 will suffice to obtain clearance needed.
  14. Black
    Black Member
    49
    thanks bud, your help is much appreciated honestly. I do have picture, but I can't tell if it's 35 or 45, I will need to take them off tomorrow and have a look.
