lowered 30mm and lower on the font than the back
AGU-TURBO Jul 28, 2010
  1. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
    Hi all i have fitted 30mm pi lowering springs all round along with new bush's and bearing on the front. my problem is now is that the car sits lower on the front than it does on the back. anyone else had this problem?
  2. AGU-TURBO
    616
  3. AGU-TURBO
    616
  4. AGU-TURBO
    616
  5. reptor245
    reptor245 Active Member
    1,168
    Why have you got VW wheel caps? You car looks just like mine its scary..lol
    Maybe its your shockers that need replacing?
  6. sportstractor
    sportstractor Chugger
    2,709
    ah sorry didn associate his with your other post. Do you have a link to the kit you bought. mine is lowere about 30mm and looks the same on the front, if anything you rear is sitting to high
  7. AGU-TURBO
    616
  8. AGU-TURBO
    616
    lol, yeh i need some new centre caps. they were on it when o bought the wheels. the springs on the back are tightly coiled at one side the open up a bit. click the link and have a look you will no what im on about. do they have to go a seartain way round. sorry about the spelling lol
  9. Matt82
    Matt82 Active Member
    2,365
    dampers wont have any bearing on ride height unless the car is resting on the bump stops
    only step next is to chop a rear coil out
  10. quattro1
    quattro1 Member
    639
    what do you mean chop a rear coil out? ^
  11. AGU-TURBO
    616
    nobody has had this happen to them then. don't realy want to start choppin coils out if there is a simple exsplanation
  12. AGU-TURBO
    616
  13. AGU-TURBO
    616
    well ive contacted pi suspension today and they say that the springs are 30mm drop front 25mm drop rear. which im not happy about as it doesn't state this on there website. anyway's anyone got a set of 30mm drop rears they would like to sell me?
  14. Matt82
    2,365
    exactly that, get an angle grinder and cut the lowest coil out. with a bit of skill you can reshape the lowest coil again to have it locate itself properly on the rear beam.... done
  15. reptor245
    1,168
    I no your not going to want to here this and each to there own but im of the opinion with "you get what you pay for" from your ebau link they seem cheap And quality and cheap dont go in the same sentence. I was considering putting lowering springs on but then when i thought if the dampers go in a year or so then i might as well just replace the lot in one kit. Just my 2 cents.
