Lower than normal running temp and lower mpg....
VAGMAN1 Nov 13, 2006
  1. VAGMAN1
    VAGMAN1 Member
    306
    running at a lower temp on average lately (80-85degC) and mpg seems to have dropped. Can't be duff temp sensor as it was only replaced in may. Any ideas or quick checks?
    (1.9TDI 110ps)
  2. pablo
    pablo Active Member
    985
    60
    thermostat?
  3. KEF A3 20V T
    KEF A3 20V T Turbo's Rule
    199
    i am having the same probs! u got vagcom???? i checked my fault codes and got one sayin coolang sensor signal irratic so im finking it mite be my coolant sensor
  4. VAGMAN1
    VAGMAN1 Member
    306
    as I said, coolant temp sensor was only replaced in may, so can't be that. nothing else tells the ECU water temp (2 feeds from the temp sender - 1 to ECU and the other to the dash display)
  5. KEF A3 20V T
    199
    Vag com will tell you for sure if it is the sensor or not!
  6. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    taking longer to start 3-4 seconds (replaced temp sensor 3 month ago)
    green one, changed non return valve filter + filter seals twice,coolant sensor gone again??????????
