Lower Exterior Door Trim
Farhan Mar 6, 2011
  1. Farhan
    Farhan Active Member
    1,234
    57
    Ah well i get my car back yesterday and i noticed the drivers door lower trim was a bit off, It wasnt sitting well. I gave it a slight tug to undo it to see why it wouldnt sit flush.
    When i tried clipping it back 2 of the little clips snapped away and wont hold near the end. The final end clip will also not hold but i dont know how that one comes undone.
    Bit worried as a bit of plastic on the inside of the actual trim has snapped away so im guessing its another replacement. Does anyone have any part numbers or know if this should be a simple enough repair.
    Really dont want to end up getting this sprayed and painted only just got my car back yesterday and really angry now :(
    Heres a photo of the part im on about.
  2. khalil
    khalil Member
    774
    had that problem not long ago too,
    its a cheap fix undo the screw behind the door( left side in the photo), and slide the trim off, what you will see is a little ovel block where the screw holds the trim to the door, the part number will be on that block, thats the part you need IF the clips are broken
  3. Farhan
    1,234
    57
    Cheers dude! ah damnit i may have done damage to the end as it tugged off quite easy. Will be heading to audi tomorrow to get parts.
    Need to get my self a copy of EKTA fairly sharpish lol.
  4. AC49er
    AC49er New Member
    I have a similar problem with my lower exterior door trim, its hanging off at the open end of the door, I have unscrewed the clip, which looks like someone has tried to bodge it back together before as its covered in glue.
    I can't see a part number on it, does anyone know the part number for this clip?
  5. Farhan
    1,234
    57
    the clips are part of the whole trim, the two end clips which have screws in them can be bought seperate but the 5 clips through the centre cannot be bought seperate.
    My stuff turned up at home today finally so when i get back illpass you on the part numbers for it.
    also what side is it as the trim and clips are not the same for the passenger/driver side
  6. AC49er
    AC49er New Member
    Mine is the drivers side lower trim, I think it is just the last end clip nearest the open end of the door which is broken, thanks.
  7. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    i scraped my door on pavement and the bottom trim is all rough.. can i just order the new strip? and does it come primed or painted?? cheers
  8. Farhan
    1,234
    57
    Yea you can order it dude, The strip comes as a whole part with clips you will just need 2 end clips but if your old ones are intact its fine.
    It comes primed but needs to be painted.
    Will get the price for it tonight and all the part numbers plus photos.
    Just as a note bro, you have an S3 so your lower door thing will be different to our S Line ones, but ill have a look on the ekta thing for you.
    Its pretty much the same fittings tho.
  9. S3RYE
    3,448
    70
    legend! thanks mate!
  10. Farhan
    1,234
    57
    Hey fella for the S3 heres the parts for the door, now i cant tell from this EKTA thing which side its for but this should help.
    2 DOOR
    For Left Side
    8P3 853 959K
    Right Side
    8P3 853 960K
    Thats for the whole strip
    For the clips it doesn't say left or right but specifically for the S3 the clip part no are as follows
    8P3 853 826
    8P3 853 825
    For Non S3 Models 2 DOORS
    Cover
    8P3 853 959 J LEFT
    8P3 853 960 J RIGHT
    For clips
    8P3 853 826B
    8P3 853 825B
    But please confirm these with the dealer just incase but thats what i ordered and mine turned up fine.
  11. AC49er
    AC49er New Member
    Thanks for the part numbers, I had been searching the net for ages looking for them.
  12. emilo
    emilo New Member
    thnks for the part no.
