Hi there,
Strange thing happened at the weekend as I drove my 2003 Audi A4 1.9 TDi PD130 Quattro Sport down to London from Leeds.
Car drove fine but roughly 100 miles into the journey I was greeted by a warning bleep and a low oil warning on the electronic display (yellow oil can)
The oil level is regularly checked along with the other fluids and in nearly 4 years of ownership I have never known the car to burn much oil or have any serious leaks. I carry out oil services myself annually and with the correct PD-spec oil too.
Anyway, when I pulled into the nearest services and checked the dipstick (on a warm engine obviously) there didn't appear to be any oil level at all. Am I right in assuming though that because the engine was warm that I wouldn't get a normal reading from the dipstick?!
I therefore purchased a litre of (extortionately overpriced ) VW-spec 5w 30 fully synthetic oil and put it in.
After setting off again the oil light stayed on but went out again after about 20 more miles.
I drove the car back up to Leeds again that evening covering 390 miles in the day and on the way back the car drove perfectly.
The following day I checked the (cool) oil level and it gave a perfectly normal reading half way up the dipstick, which seemed strange because if the oil was really low the day before, a litre of oil from the services wouldn't have filled it up to halfway, and also if there was no oil loss and the warning light was just an electrical gremlin, then surely the oil dipstick reading the following day would have been high?!
Either way, I'm rather confused and worried about some form of imminent oil pump failure or leak etc.
Could anyone shed any light on what could have caused this sudden apparent oil leak? Or if this is a common glitch on older cars?
Finally, one last thing is that I think my EGR is on its way out and has been leaking a bit of oil vapour over the last 18 months or so. I'm not sure its enough to have caused this though.
Any help would be much appreciated
J
J
