Low oil level warning!!!
Keggers Nov 9, 2013
  1. Keggers
    Keggers Member
    75
    Hi there, I only just fixed my coolant sensor then a few days later I now have the low oil level indicator coming on straight after I start the car. I've checked the oil level and slightly topped it up but the indicator stays on!! My book says there is also a warning for oil level sensor when it's faulty so I'm not sure if its the sensor or not.
    Anyone got any ideas?
    Thank you.
  2. wesmaster
    wesmaster Member
    300
    20
    I had this, fitted a new level sensor and still got message, disconnected battery for 5 mins and was sorted!
    A slight glitch with instrument cluster.
  3. Keggers
    Keggers Member
    75
    Brill, I'll try that tomorrow then, thanks.
  4. Keggers
    Keggers Member
    75
    Went out in car last night and seems to have self rectified its self!!
  5. adamss24
    adamss24 Well-Known Member
    4,578
    402
    Usually the micro switch built in the bonnet lock is faulty, there's something in the code that stipulate one needs to lift the bonnet and check the oil level then it goes off ! As above, disconnecting the battery has a similar effect as it's resetting the gauge...
