Low oil indicator
Beeblebrox May 7, 2013
  1. Beeblebrox
    Beeblebrox Member
    94
    Hi guys I seem to have a fault with my oil indicator I check my oil in the morning with a cold engine and it reads full on the dip stick but after the engine warms but not all the time the warning indicator flashes up on the dis and stays but if I open the bonnet and check the dip stick it goes dose this look like a fault with the sensor or the beginning of a more serious problem cheers for help
  2. mm707
    mm707 Member
    278
    Most likely a fault with the sensor. Mine is the same, planning on replacing it when I change the oil in a couple of months.
    Opening the bonnet resets the warning light.
