Low judder/vibration at idle
Clach Feb 18, 2008
  1. Clach
    Clach A3 - 1.8Ts
    971
    Hi there,
    Maybe it is me getting all paranoid because my A3 has been running sweet lately after an Amplifier injector failure, but at idle there is a slight/low and noticeable vibration through the brake, and the rest of the car....(I have an Auto). Also, occasionly the needle dips a little below 800 rpm at idle, nothing much, then recovers. Either way, there is still a low but noticeable enough vibration. Noticeable enough, for instance, to make the sun visor shake a little and the armrest, etc ... Nothing obvious under the bonnet I am afraid...
    Is it just me, a common enough problem with a W reg or is that the/one coilpacks on there way out... :sorry:
    A thought to put my mind at rest..?
    Cheers folks,
    Craig
  2. Clach
    Clach A3 - 1.8Ts
    971
    Ach, maybe it is me...but defo feels a wee bit too juddery for me!
  3. Clach
    Clach A3 - 1.8Ts
    971
    No there is defo. something wrong. It is intermittent and noticeable at idle when it happens to the point where my non-obsessive Audi fan wife even mentioned it....!!!
    Any thoughts?
  4. 2low4u
    2low4u Active Member
    199
    42
    The air conditioning compressor kicking in will make the revs dip slightly, and a small judder will be felt.
  5. abdus
    abdus Top Gear VCDS Map User
    1,827
    when the revs dip, is it like it's going to cut off?
    maybe throttle body need cleaning?
  6. Clach
    Clach A3 - 1.8Ts
    971
    Thought about that. I remember you sent me some info on this a while back, a summer job (if not before) me thinks.
  7. Clach
    Clach A3 - 1.8Ts
    971
    Thanks for the reply, but sadly not in this case mate...
    Any other thoughts welcome :icon_thumright:
  8. steveborner
    steveborner New Member
    22
    idle control valve may need a little tweaking? you tried a diagnostics test for an error code?
  9. Clach
    Clach A3 - 1.8Ts
    971
    Going to put it in for a service, will see what comes up. Just had the ignition amplifier changed at Audi too - I bet they f'd it up....! ;-(
  10. steve-tt
    steve-tt Member
    72
    get your engine dog mount bushes checked,if they're worn this could cause vibration on tickover.
  11. Clach
    Clach A3 - 1.8Ts
    971
    Cheers. Will do. putting the car in for a service soon..
  12. Clach
    Clach A3 - 1.8Ts
    971
    Problem solved: No codes on Vag com (which was good). Had the Air and Fuel filter changed at Vag techniques near Henley/Reading (excellent service) and the problem has gone.
    Two possibilities: Air filter was never changed by Fontain at its last service, and air flow was disrupted. - most likely IMO
    or, the fuel filter was getting clogged etc...
    Thanks for advice...
