Low coolent level :o/ ???
Blade Sep 27, 2007
  1. Blade
    Blade New Member
    No obvious signs of a leak. Any thoughts ?? Over 1,000 miles, never checked before so have no idea how long its been like this.
  2. s4harv
    s4harv New Member
    13
    Have been checking my water and oil when I clean it each week and after nearly 5K miles neither have budged.
    Just top it up and hopefully just cr@p dealer inspection! - probarbly worth telling them though as if it were a major defect you told them very early on?
  3. gjcknocker
    gjcknocker Member
    99
    Definitely worth a mention to dealership
  4. enda1
    enda1 Member
    436
    Just make sure you get G12 antifreeze if your topping it up
  5. Jo Sharp
    Jo Sharp Member
    131
    I have just had exactly the same on my new A3.
    Took it to the dealer last week who gave it a thorough inspection top and underneath the engine - no sign of a leak anywhere. Tech said this was most likely an airlock in the coolant from the factory that has shifted after being run at higher revs for the first time ( and unlikely to be bullsh*tting me as it a german technician in a garage I have used for over 10 years).
    Coolant has been topped up and in the last 200 miles has stayed at max.
    If it drops again they will take it back in for a pressure test to check the head gasket and cylinder head for leaks
