Low back pressure with TBE
Fast,not furious Nov 4, 2008
  1. Fast,not furious
    Fast,not furious Dealing with an OCD
    416
    Now my custom turbo back exhaust has been fitted,(by Exhausts UK,Sheffield)the car's suffering with boost problems. Steve Jr at Statller reckons it's the exhaust that's causing the problem,and recommended putting the old exhaust back on,and then data logging,but obviously that's gonna cost...and then a replacement(maybe my custom one,modified?)or Milltek will have to be fitted again...more money...
    Although it has a 200 cell sports cat,the complete system is flowing too well,so not creating enough back pressure,causing the turbo overboost,so i'm losing torque.
    What should i do? Spend more at Exhausts UK,fitting another cat or something to restrict the flow? Spend even more and go full Milltek?
    I've no idea what i should do next! I've even considered just having the Milltek downpipe and sports cat,but the combination still might not flow correctly with the rest of the system.
    Its currently a 3" downpipe,200 cell sports cat,2.5" pipe,mid silencer,2.5" pipe,cobra rear box.
    I'm running a GIAC hammer map and Forge CAI,both worked seemlessly before the exhaust went on.
  2. dunk
    dunk Member
    770
    as a general rule, low back pressure from a highflow cat and good exhaust is usally a good thing - it is going to give you less lag, lower exhaust and turbo temperatures therefore more airflow and pressure with less stress on the engine components.
    what you may need is a custom remap to ensure that you have correct boost pressure and fuelling for the new setup, rather than undo the (presumably good and working properly) effects from the exhaust/cat
  3. boggysv
    boggysv Member
    573
    <beer induced thought>
    why not try to plug your exhaust outlet and see what happens?
  4. Fast,not furious
    416
    :tumble:
  5. jonnyc
    jonnyc Member
    858
    Its half 4 mate!! haha..
  6. Fast,not furious
    416
    Could it be the fuel pump??
  7. Sohrob
    Sohrob Member
    351
    i am very dubious as to how good custom systems are, if you look at a miltek exhaust it has been designed and developed for that vehicle.
    On previous cars i have had custom exhausts and they are just made to fit there and then without any development or research into flow rates, where the bends should be etc etc.
    If it was me i wouldnt spend anymore money and go back to std or get a miltek.
    I cant see it being your fuel pump but maybe take it into Audi for a diagnostics check (be prepared to loose your map thoug!!!)
  8. crazylegscrane
    crazylegscrane Active Member
    253
    66
    :iagree: back to standard or miltek and if that sorts it get your money back for the custom exhaust as it dosen't seem fit for purpose
  9. Fast,not furious
    416
    Update...
    It was the fuel pump!
    Exhausts Uk put me in touch with JBS Auto Design,and after a chat with them,the car was booked in for a health check....and the patient has responded well to surgery :tapedshut:
  10. jonnyc
    jonnyc Member
    858
    Eeeeesh what did I say ;)
    Its a bit of a worry to hear that a fuel pump in an S3 has gone bad though, can you expand on the problems?
  11. Fast,not furious
    416
    Jonny
    Mine was one of the earlier 'H' pumps,which some are having problems with. It seems that it was just unable to supply enough juice for the extra demands the exhaust seemed to make. It was fine before the exhaust went on,so i guess the free flowing exhaust and extra horses were asking more than it could give,hence loss of boost. Logs showed it only able to sustain 110 bar,but with the new pump,she's now holding 140
  12. jonnyc
    jonnyc Member
    858
    Ah cool..
    Its more like 110bar and 140bar now.. The FSI fuel rail pressure is immense!
    Glad you got it sorted out anyways mate :)
    Jonny
  13. Fast,not furious
    416
    That's what i said :redface: (does a quick edit!)...i thought that sounded low as soon as i wrote it...no wonder i had problems...lol
    Yeah,it's grand now mate
  14. jonnyc
    jonnyc Member
    858
    lol, sorry must have read it wrong ;)
    Have fun mate!
  15. Fast,not furious
    416
    Lol,yeah - i reckon you've been pulling to many G's round the circuit recently and your eyes are still blurred!:unsure:
