Loud wining/whizzing noise on start up
HOTTIGGER Jun 21, 2012
  1. HOTTIGGER
    HOTTIGGER Member
    99
    hi all as above, my s3 makes a loud wining noise when first started, seem to be only when its cold or bin left for a bit, my m8 said it was the cold start on the air compreser, ive scearched threads for cold start on the air compreser but no joy, its not coming from the starter or aulnater, i could not really tell if it was coming from the air con pump, its a mad loud whining/drilling noise and it sounds pants. it goes off when you drive off or leave it long enough it will seem to wind down and the revs drop to normal, ive comw across threads about sai pumps. could this be wots making my mad noise? can it just be unpluged or sumthing? thanks in advance
  2. Paradox1
    Paradox1 Active Member
    1,833
    88
    i started to get the same a few days ago. at a guess i think its the SAI but not 100%
  3. Gavin G
    Gavin G Active Member Audi A4 S-line owners group TDi saloon
    174
    25
    Think this is common mine does it aswell and it's related to the oil pick up maybe someone else can confirm this? It does no harm as far as im aware.
  4. Paradox1
    1,833
    88
    oil pick-up??
    My old pump isnt even a year old. I swear I could right a book about the problems with these cars lol
  5. HOTTIGGER
    HOTTIGGER Member
    99
    i think mine is sai after reading on hear, but like you id like to be 100 percent sure m8.
  6. lgooch
    lgooch Well-Known Member VCDS Map User It's my birthday
    1,110
    139
    Sounds like the secondary air intake on its way out. All it does is allow the CAT in your exhaust warm up quicker, hence if you rev the engine from cold it will quieten down quicker and the revs will drop slightly. Search on uk-mkivs.net as there is a how to over there on how to fix them. The noise should be coming from the drivers side front wheel well
  7. HOTTIGGER
    HOTTIGGER Member
    99
    hi m8 thanks for reaply, it sounds like its come from the front of the car down by the air con pump , i carnt quite pip point it, it a loud hover/drill type sound.
  8. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
  9. lgooch
    1,110
    139
    does it sound like this. if it does then you have your answer. The SAI is not far from the air con pump but you would easily be able to tell if it was the air con pump by turning it on and off.
    Audi secondary air injection pump - YouTube
  10. lgooch
    1,110
    139
  11. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    mine does the same too but its getting louder my pick up pipe is clean and air con working fine so god nose plus i dont have a secondry air pump on my amk
  12. <tuffty/>
    20,990
    3,760
    If its a high pitched squeal type noise its the fans... when it does it again, turn off the aircon by hitting the econ button... if the noise goes its the fans..
    Mine does this
  13. HOTTIGGER
    HOTTIGGER Member
    99
    hi m8 thanks for the reaply, yes thats the sound its making, will it be ok to just unplug the wires ?
  14. HOTTIGGER
    HOTTIGGER Member
    99
  15. Paradox1
    1,833
    88
    i think if you unplug it you may get a EML but thats all
  16. lgooch
    1,110
    139
    Yes take the multiplug off. Start your car and if the noise is not there then you have pinpointed your problem
