loud whoosssshhhhhhhhhh noise normal? air leak?
JUS3IN May 26, 2013
  1. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    im guessing not, and as my current maf reading is showing around 180bhp then theres defo a problem somewhere.... this noise started after fitting my v3 manifold and downpipe but not straight after!? when i come on boost i get the whhhoossssshhhhhhhhht noise which stays all teh time on full boost and its very loud, sounds like a skyline at full chat but obviously its not... i have no codes now, anyone know what i could log to determine an airleak, everything i cat get too ive checked bottom intercooler pipes, turbo elbow ect... could a small pipe make a massive noise?
    surely if my downpipe or mani/turbo nuts had come loose it would be obviously an exhaust blow noise and all the time?
    theres lots of oil in my pipes but ive put that down to slightly over filling when i refitted the turbo, i was thinking it had blown it out of the crank case breather/ pcv(is that what it is?)?
    spec is in my signiture and car is in my garage, apy s3...
  2. <tuffty/>
    21,672
    4,101
    My money is on the relentless manifold having burnt a hole in the orange pipe coming off the turbo to the top charge pipe...
    Got a heatshield in there?
  3. JUS3IN
    1,159
    102
    no heatshiel but no hole changed back to the orange pipe today to eliminate the aftermarket blue one i had there which was a poor fit turbo side, also no damage to the blue one... with the oily intercooler pipes you'd think any leaks would be very obvious... not so, the passenger intercooler lower connection i had off due to oily residue and refitted with new clips... still the same, drivers side looked good..
    think i need to have a good look tomorrow, are the hard plastic ones likely to split? or the metal one?
    can i log anything dude?
  4. <tuffty/>
    21,672
    4,101
    Smoke test FTW dude...
  5. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,178
    215
    I am currently going through the same thing since v3 manifold and dp fitted. It was fine for first few weeks...
    The engine sounds a lot louder from manifold and slight ticking when cold so I'm placing my money on bolts expanding and blowing past the gasket on the turbo.
    I can also hear my diverter valve dumping louder, almost asif the tip isn't fully on the turbo and creating a massive suction noise within the bay on lag, then a loud wooosh scream on boost. Doesn't help with aload of exhaust leaks I have already though lol.
    I'm sorting it all out next weekend so I will update with findings.
    I don't have vcds though so can't log anything, just know that it doesn't feel right. Major power loss/flatness again - very noticeable....last time the dyno proved power loss at 180bhp, no good for a stage 1 mapped bam s3 tbh.
  6. ShaunS3
    1,178
    215
    I really need a smoke test but don't know anywhere local that does it :(
  7. JUS3IN
    1,159
    102
    cheers shaun, we'll work together on this one then!-)
  8. JUS3IN
    1,159
    102
    thanks tuffty, i'll try to sort one, at the isle of man tt next weekend tho!-)
  9. ShaunS3
    1,178
    215
    I'm actually glad it isn't just mine tbh lol
    I have a few new bits to put on like b5 tip, top charge hose, turbosmart dv, s2000 filter.
    Going to get new gaskets again just incase they have popped.
  10. JUS3IN
    1,159
    102
    same lol, how did you fit yours? done mine on the car. hopefully they arnt cracked already!-( might have a go at tightening some nuts while she's warm tomorrow, see if it makes a difference... i'll update here then.
  11. ShaunS3
    1,178
    215
    Mine was fitted with the engine out on a stand. As was the turbo and dp.
  12. JUS3IN
    1,159
    102
    strange my bolts were all very tight.... im having a look in a minute so i'll let you know if any have come loose.... hopefully its just air leaks... unless we've somehow ended up with fakes off ebay and the cats super restrictive!!?
  13. JUS3IN
    1,159
    102
    saying that im sure i werent making the wssshhhhhh when i fitted it....
  14. JUS3IN
    1,159
    102
    hopefully its just an air leak, i used genuine gaskets too...
  15. JUS3IN
    1,159
    102
    its turbo to manifolt flange, i used 3 studs and 14mm brass nuts..... now im thinking of changing because they are likely to undo again.... any suggestions? hope ive not got to remove the turbo again, probably have ggggggrrrrrrrrr.... hey at least we know whats wrong.
  16. JUS3IN
    1,159
    102
    right, just replaced the brass 14mm nuts with some chunky steel 17mm lockers. i also skimmed a bit of each washer thus making 1/4 of the washer thinner, so they clear the weld on the manifold and sit nice and flush... done all this without undoing the driveshaft this time, probably would've been easier and maybe quicker if i did? had to drop the downpipe tho and the turbo bracket.... still not 100% on that awful one under the manifold, if it does undo again (which im pretty sure it will), then it will be going to my pals garage... had enough now! either that or i'll just refit th standard mani and smash the v3 up with an axe!-)
  17. ShaunS3
    1,178
    215
    What a good guess :)
    Was it quite obvious?
  18. JUS3IN
    1,159
    102
    Yeah, my nuts were up 10mm of the flange!!!
    ShaunS3 likes this.
  19. ShaunS3
    1,178
    215
    I hope it's just the same thing on mine tbh and not a cracked manifold....
    Running any better now?
  20. JUS3IN
    1,159
    102
    Haven't had a chance to log it yet but sounds good again, more crisp... I think as it gradually un does itself you don't notice how ruff it sounds lol!
  21. ShaunS3
    1,178
    215
    Yeah, mine sounds really rough at the moment. Should be silky smooth sounding from the engine bay lol
  22. badger5
    9,553
    2,027
    stuff only undoes when its not done up right first time with decent fixings etc
    all understandable given how shyte access is on a relentless
    they dont come undone when done up tight
  23. JUS3IN
    1,159
    102
    right as im still not happy, still a hiss on boost im going to redo it when im back off holiday... need some advise on parts?
    going for a new gasket and then these if they are advised, right size? are the ko4 flanges fine m10?
    Metric Manifold Studs M10 x 40 mm Qty 20 - Manifold Studs & Nuts | eBay
    then which nuts? these?
    M10 x 1.25mm FLANGED ALL METAL EXHAUST MANIFOLD LOCKING NUTS 2pack | eBay
    or these?
    MANIFOLD NUTS COPPER FLASHED SELF LOCKING METRIC M10 X 1.5mm PITCH PACK OF 10 | eBay
    or these?
    M10 Aerotight All Steel YB RS Escort Sierra Cosworth Manifold Turbo Lock Nut | eBay
    if not any of these please advice anyone, what worked for you?
  24. badger5
    9,553
    2,027
    top nut you linked is wrong pitch thread btw
    I have used normal stainless nut and nordlock previously.. not come undone.
    used exhaust stud for the stud.. but key bit I did them turbo up to the manifold on the bench where you can Properly tighten the hidden fixing.. which is pretty muc impossible to do on the car to as tight
    good luck
