  1. sohail579
    sohail579 New Member
    Hey All
    got my self a 2003 A3 2.0 FSI one thing that i have noticed is that sometimes the Fan is really loud so loud you can actually hear it from a distance away and inside the car..
    Is this normal??
    thanks
  2. Mines like that on my 2.0TDi, sounds like a quiet hover if you stand near it only when stationary, I don't mind it
  3. sohail579
    mine is far from a quiet hover i have noticed it when stationary and while driving
  4. Dec
    Dec Active Member
    319
    30
    Mine goes pretty loud too sometimes. It appears to be the air con fan on the radiator, as I turned my air con off for a few days to see if it was that, and even over the hot weather the fan still did not come on.
    Put the air con back on to say 23c and it makes a huge noise while its working hard again. Not sure if there is a solution, or if its just how they are really, but would be interested to know, incase the bearing is gone or something :)
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    usually it can stat getting loud when your air con pressure is running low as the fan goes into turbo to compensate, worth a check on vag com
  6. Dec
    Dec Active Member
    319
    30
    Is that when you have to get it Recharged? Or more serious than that?
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    usually jsut a recharge
  8. sohail579
    ok ran vag com on the car and got this error could this be the problem?
    18354 - Control Module 1 for Coolant Fan: Defective
  9. PH1L
    PH1L Gievf Buckets
    3,851
    40
    check out the ross tech wiki
  10. sohail579
    tried looking there but cant seem to find anything in this error code
  11. sohail579
    can anyone help me?
  12. sohail579
    ok i have now noticed that when i put the AC on the fan comes on and stays on at full speed when i switch the econ on so air con is off the fan switches off.. i had my air con refilled but same problem..
    any suggestions?
  13. xnox202
    xnox202 Member
    193
    Fan Thermostat?
  14. sohail579
    where would that be located?
  15. Dec
    Dec Active Member
    319
    30
    Exactly what mine does as well. No idea what it is though, haven't had a chance to look yet! Getting kind of worried now so will get it looked at asap.
  16. sohail579
    let me know how it goes im currently investigating aswel
    Have you had it hooked up to VAG COM? i get a fan controller error
  17. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Anyone get to the bottom of this? I'm having similar issues except only since I've had the system regassed!?
    Azeem
  18. TDI140
    TDI140 Well-Known Member
    1,632
    175
    I sold my ch wheels on sunday and the guy came to pick them up in a mk5 golf 1.6 his fan was continously on for 30minutes and it was three times louder than mine on my a3 he said he doesnt know why
