loud bang and no power
mickb Apr 18, 2013
  1. mickb
    mickb New Member
    recently had clutch fly wheel slave cylinder and cambelt changed.
    Today there was a loud bang and lots of smoke from exhaust as i changed from 1st to 2nd gear now it sounds like a tank and has no power.
    any suggestions
  2. mickb
    mickb New Member
    its a 2006 1.9 tdi 105 bhp version
  3. Raz Wan
    Raz Wan New Member
    Any ideas on what colour the smoke was?
  4. mickb
    mickb New Member
    black smoke
  5. Sidhu88
    Sidhu88 Active Member
    808
    76
    Sounds like the turbos gone, could be wrong. Although the fact u had ur cambelt changed could suggest that it may have been done wrong, full throttle from first to second with dodgy timing may have caused something to go wrong in a big way.
    The "tank" sound is how the car sounds with no boost pressure, i've experienced this plenty of times when my car had EGR probs, it had minimal power, enough to drive it somewhere but couldn't do no more than about 40-50.
    Plooms of white smoke from the exhaust is normally what u'll find when the turbo finally gives in.
  6. Raz Wan
    Raz Wan New Member
    Its best to get it checked out, My turbo just blew and i have an automatic so could not stall the car. Its scary!! Mine put out a literally cloud of grey/white smoke for miles high until engine finally turned off.
  7. mickb
    mickb New Member
    black smoke not white
    sunday driving style not giving it any beans
  8. A3Craig
    A3Craig Member
    85
    Check your boost pipes as one could of been taken off when work was carried out and not clip together properly
  9. J8TT X
    J8TT X Member
    360
    9
    Id say your boost pipes have blown off.
    Happened to me, had new pipes and the turbo reconditioned to fix it.
  10. mookster
    mookster Active Member quattro
    271
    72
    If it's not a boost pipe then it may be the turbo. I'm less familiar with these but in an old car I had I got a loud bang with similar results - turbo housing had cracked between the exducer and wastegate port.
  11. CHEZ
    CHEZ moderately amusing Supporter
    4,171
    839
    +1 on the boost pipe!
    happened to me!
    luckily the large one just needed a new jubilee clip
  12. max69vk
    max69vk Active Member
    862
    57
    Boost pipe = black smoke
    Turbo = white/blue smoke
  13. Raz Wan
    Raz Wan New Member
    ah yes, deffo boost pipe popped off.
  14. phil76
    phil76 Active Member
    572
    40
    I agree with Max above normally black smoke is over fuelling caused by the ecu and other components recognising there is too much air so its starts chucking fuel in to compensate it over boosting,turbo light grey white smoke and depending on how the turbo has gone but a good symptom is it chucking out the light coloured smoke on tick over and it clearing when you rev it until revs drop down to tick over again.
    Check the boost hoses properly all of them give them a tug both ends to make sure they are not pulling out of what they are housed in,as sometimes the metal clips break but not fully so underload the pipes are pulling apart
  15. mickb
    mickb New Member
    all sorted now
    thanks for the reply`s
    i took the guard off underneath the engine to find a bit of oil on the front nearside of the guard the pipe above had come out of it`s mounting i think the circlip wasnt fitted correctly
    thanks
    Mick
  16. mookster
    271
    72
  17. grr666
    grr666 Member
    171
    19
    My moneys on this as well. I was into the tuned
    tdi scene before coming here. Uprated clips are sometimes the answer.
    Full Stainless Mikalor Supra W4 (Pro) Hose Clamps
    No power as you are probably going into limp mode.
