Hi,
After I can sorted the DPF regeneration off on my car but now I am getting more problems like start/stop now never active and heater seem like not working any more no hot air come out and really feel like no air to breath too when I set temp on Hi.
Seem like lots of thing going wrong with my car T_T
Here the VCDs scan result
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
Address 01: Engine (J623-CNHA) Labels: None
Part No SW: 04L 906 021 FQ HW: 04L 907 309
Component: R4 2,0L EDC X23 1649
Revision: 85X23---
Coding: 12254012242401080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
ROD: EV_ECM20TDI01104L906021FQ.rod
VCID: 79F98782F818788AE7-802C
1 Fault Found:
19208 - EGR System
P0401 00 [096] - Insufficient Flow
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 133721 km
Date: 2016.09.03
Time: 22:15:03
Engine speed: 1995.50 /min
Normed load value: 56.1 %
Vehicle speed: 55 km/h
Coolant temperature: 90 C
Intake air temperature: 83 C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.140 V
Unlearning counter according OBD: 13
EGR travel diagnosis: strongly increased NOx emission: -201.4 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.02 %
EGR travel diagnosis: marginally increased NOx emission: -34.9 kg/h
Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 100.00 %
Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 79.19 %
Pressure after throttle valve: calculated: 223.0 hPa
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.9768
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Revision: -------- Serial number: --------------
Coding: 06A29E41604579829B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_AU57.rod
VCID: 3F8D299AA6BC96BA99-806A
6 Faults Found:
13056 - Function Restricted due to Missing Message(s)
U1111 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 133948 km
Date: 2016.09.04
Time: 12:05:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 04
Bit Info 4: 1F
Uz: A3
Unlearning counter according OBD: 14
176384 - Function Restriction due to Implausible Message(s)
U1112 00 [032] - -
176896 - Function Restriction due to Implausible Message(s)
U1112 00 [032] - -
177408 - Function Restriction due to Implausible Message(s)
U1112 00 [032] - -
177664 - Function Restriction due to Implausible Message(s)
U1112 00 [032] - -
177920 - Function Restriction due to Implausible Message(s)
U1112 00 [032] - -
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Revision: 00002001
Coding: 01B9704E000000000000
VCID: 7AFB988EF51E7392EE-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 3214000170841006
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 96
Mileage: 133366 km
Time Indication: 0
Date: 2016.09.03
Time: 11:17:15
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4G0 820 043 CC HW: 4G0 820 043 CC
Component: KLIMA 4 ZONEN H14 0112
Serial number: 18121400040838
Coding: 34220978210000
ASAM Dataset: EV_AirCondiComfoUDS 003008
ROD: EV_AirCondiComfoUDS.rod
VCID: 62CBC0EE758E9B52D6-8036
No fault code found.
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00000968789902
Coding: 2600001400349FE00181408000001D0CCF9DC60827090201000008206100140200400024030000
VCID: 71E9BFA2A86830CA5F-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 141118 H37 0080
Serial number: 141128195303
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 23569356
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 15 12 2014 00000942
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: BB88C567000000000001
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 96
Mileage: 133366 km
Time Indication: 0
Date: 2016.09.03
Time: 11:17:15
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1002MV75
Coding: 30333130313630323639554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3B755D8AB2A48A9AB5-806E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40552R6CO81GD
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB405J2R6CO9PB5
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB404V3201U819Z
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB404V3201UB9C7
Crash sensor for front airbag: driver side:
Serial number: 3554VRB404T33RVO58HQ
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB405933RVOE11.
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862NLG000FA
Coding: 000035
VCID: 3B755D8ABAA48A9AB5-806E
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0010
Serial number: 28 11 2014 D0094637
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 951 A HW: 4G8 920 951 A
Component: MDieGb H43 0506
Revision: 28450303 Serial number: 658121214592025
Coding: 33A612000B412600010000
ASAM Dataset: EV_RBC7KMID 004050
ROD: EV_RBC7KMID.rod
VCID: 2E5364DE71D66F3202-807A
1 Fault Found:
1048578 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 56
Mileage: 133366 km
Date: 2016.09.03
Time: 11:29:59
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G5 907 468 D HW: 4G5 907 468 C
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001665684
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 001024
ROD: EV_GatewPkoUDS_AU57.rod
VCID: 36634CBE898657F24A-8062
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 0636395303
Voltage stabilizer:
1 Fault Found:
12291 - Energy Management Active
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 115
Mileage: 134204 km
Date: 2016.09.06
Time: 10:01:33
Voltage terminal 30: 12.7 V
Voltage terminal 15: 0.0 V
Control Module temperature: 20 C
System status: Awake_Timer_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 1
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 13121400040148
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 3D715392ACB084AA8B-8068
1 Fault Found:
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 113
Mileage: 137519 km
Date: 2016.09.17
Time: 21:24:12
Outside air temperature: 14.5 C
Left rear vent temperature: 18.2 C
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720E98UL
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_AU57.rod
VCID: 336575AA9AF442DA6D-8066
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F16014001620002080002
VCID: 479D317AF66CDE7A21-8012
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 96
Mileage: 133366 km
Time Indication: 0
Date: 2016.09.03
Time: 11:17:19
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0011311310
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_AU57.rod
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0355979303
Coding: 013B0622A0B930008320090400010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 96
Mileage: 133366 km
Time Indication: 0
Date: 2016.09.03
Time: 11:17:15
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0507
VCID: 46833C7EF166C772DA-8012
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 96
Mileage: 133366 km
Time Indication: 0
Date: 2016.09.03
Time: 11:17:19
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001812412
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_AU57.rod
VCID: 31697FA260E870CA1F-8064
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4G1 035 192 A HW: 4G1 035 192 A
Component: RMC Nav Plus H61 0139
Coding: 0101010001C15B47082B060301010000000000
VCID: 21498FE23808C04A8F-8074
Subsystem 1 - Part No: 8X0 919 884 H
Component: P28-50-14.06 0001
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464K+0E2693025
Subsystem 3 - Part No SW: 4G2 919 610 E HW: 4G2 919 610 E
Component: E380 BDT C7 H20 0250
Serial number: 90349NL600045
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0507
Coding: 010F14004001620002080002
VCID: 49993742E078280A37-801C
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 355401403
Coding: 093205C010
ASAM Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0507
Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 143360761
ASAM Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100.rod
VCID: 2D5163D27CD0142A3B-8078
Revision: 85X23---
1 Fault Found:
19208 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 133721 km
Date: 2016.09.03
Time: 22:15:03
6 Faults Found:
U1111 00 [040] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 133948 km
Date: 2016.09.04
Time: 12:05:49
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 04
Bit Info 4: 1F
Uz: A3
U1112 00 [032] - -
U1112 00 [032] - -
U1112 00 [032] - -
U1112 00 [032] - -
U1112 00 [032] - -
Revision: 00002001
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 96
Mileage: 133366 km
Time Indication: 0
Date: 2016.09.03
Time: 11:17:15
Coding: 0045F7
Coding: 02006D
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 96
Mileage: 133366 km
Time Indication: 0
Date: 2016.09.03
Time: 11:17:15
Coding: 000035
1 Fault Found:
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 56
Mileage: 133366 km
Date: 2016.09.03
Time: 11:29:59
Coding: C0CD074418
Voltage stabilizer:
1 Fault Found:
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 115
Mileage: 134204 km
Date: 2016.09.06
Time: 10:01:33
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Coding: 22
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 113
Mileage: 137519 km
Date: 2016.09.17
Time: 21:24:12
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 96
Mileage: 133366 km
Time Indication: 0
Date: 2016.09.03
Time: 11:17:19
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 96
Mileage: 133366 km
Time Indication: 0
Date: 2016.09.03
Time: 11:17:15
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 96
Mileage: 133366 km
Time Indication: 0
Date: 2016.09.03
Time: 11:17:19
Coding: 093205C010
