Lost AM reception on Symphony II unit
DuncS3 Feb 25, 2006
  1. DuncS3
    DuncS3 Member
    289
    Okay, not as exciting as big turbos etc but has anyone experienced this?
    Basically FM etc works perfectly as always, but for the last couple of months my AM reception has gone to pot, bascially cant listen to it, almost no reception - used to be perfectly clear
    any ideas?
    Dunc
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    what year is your car? There were signal amps originally in the roof aerial but when those failed it was a ****** to replace so they changed it into the head unit. I noticed this when I swapped to a kenwood head unit - my AM was useless. I bought a booster and shoehorned it in behind the HU. I guess it could be a failure of this either on the aerial or in the headunit.
  3. DuncS3
    DuncS3 Member
    289
  4. dickys3
    2,963
    23
    I think AM comes from the head unit so it doesn't use the aerial. Perhaps your head unit is knackered?
  5. S3Steve
    S3Steve Active Member
    1,621
    20
    I had a similar problem on my S3 which after much pain I traced to an aerial splitter that sits ontop of the sub box. Their was a loose connector inside of it which i resoldered, this cured the problem.
  6. DuncS3
    DuncS3 Member
    289
    Cheers - I dont think the head unit is 'knackered' as everything else works perfectly fine
    I'll start having a look at the aerial splitter
    Dunc
  7. AndyS3
    AndyS3 Member
    133
    Hi dunk
    Had the same problem a while ago, it was the aerial. I had it replaced under warrenty and have never had a problem since. If i recall they said water had got into it, sounded like a common problem as they were able to tell me it was probably the aerial when i described the problem.
  8. DuncS3
    DuncS3 Member
    289
    Is the aerial easy to swap out? Anyone know? depends on price etc but if its easy to swap might try that first.
    Dunc
  9. S3Steve
    1,621
    20
    The aerial on the roof is quite easy to change, just remove the roof lining and undo the bolt that holds the aerial to the roof. The aerial has a built in amp in the base, just be careful not to damage the rubber seal at the base of the aerial.
    However having said all this i beleive the am reception is through an aerial in the rear window and not the roof mounted aerial. As your problem is with AM reception I think you should check the aerial splitter and the cable that runs from it to the rear screen first.
