Lost a little boost after fitting turbo back exhaust
Inertiauk Jun 15, 2011
  1. Inertiauk
    Inertiauk Active Member
    574
    29
    I had my Pipewerx Dwonpipe, decat, and my miltek cat back fitted today.
    I haven't yet had the stage 2 map, planning on a trip to Rtech soon though.
    The boost seems a bit hesitant at the top end now. In fourth/fifth gear pointed up hill with WOT it used to peak at around 24psi, then drop to 22 and hold for a bit before it started to drop off in higher revs.
    It now peaks at 21/22 psi, flutters about a bit and drops off quicker than it used to.
    Is this just because I need my MAP to match the new down pipe / system ?
    or as i suspect could it be a weak turbo which has been pushed a bit harder due to the pipe and is dieing ?
    Or something else ?
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    You may want to reset the ecu/throttle body has the characteristics have changed and it will need to learn its new lungs....
  3. Inertiauk
    574
    29
    Thanks, I will do that.
