Loss of power, Sounds like a scooby :(
S3PDX Mar 2, 2011
  1. S3PDX
    S3PDX New Member
    Hey all, driving my car (Audi A3 1.8T Sport 99) last night and as the title says i have some intimitant loss off power and it sounded like a scooby... If i wanted it to sound like a scooby i would have bought one :wacko: lol, i was woundering if anyone has had a simalar problem
    Thanks In Advance
  2. auroan
    auroan Active Member
    1,669
    Sounds like you've dropped a cylinder. Check your coil packs and see if one has failed.
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Coil packs!
  4. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    he has a 99, coilpacks are less common on AGU engines. I'd go for ignition module first. Thats what mine was.
  5. S3PDX
    S3PDX New Member
    Thank you for your reply, i had a small feeling it could have been something like this thank you :)
  6. JS1500
    JS1500 Howdy
    1,166
    10
    Phone your local Audi dealer's Servicing Dept and check if your car is on the recall list for free coilpack replacements!
  7. badger5
    9,543
    2,022
    coil packs also... bolt downs are good but not impervious to failure
  8. S3PDX
    S3PDX New Member
    Not on recall list :( but £104inc VAT unipart 4 instock
  9. aragorn
    18,490
    855
    If it has an ignition module, i'd be swapping that out before the coils.
    When they fail they often drop cylinder 2 first.
  10. badger5
    9,543
    2,022
    swap coils and see if the misfire follows the coil or the cylinder will confirm obviously
  11. DaveA3
    2,370
    15
    do you know anyone else with an agu? either golf or a3
  12. aragorn
    18,490
    855
    A4/A6/Passat with an AEB/AJL motor also use the same coils and ignition modules as well ;)
    I've got a spare you can try if your local.
  13. S3KO4
    S3KO4 Member
    850
    undo the coil pack connections one at a time, then you would know which one is at fault.
  14. KB
    KB Member
    195
    my s3 did this, was a pipe split that comes off the sero. all so the clutch was slow an the brakes didnt work so well,
  15. TheButtonz
    TheButtonz Member
    97
    My misfire was a duff HT lead. Remember to check these, as I changed the coil pack and plugs before realising this.
  16. Sandip
    2,456
    99
    :iagree:
    Pull each coilpack out to test which one has failed, swap that coilpack with a working pack. If that coil doesn't work when swapped with the working one, it's the ICM.
  17. s3dave
    10,110
    736
    No HT leads on a 1.8t
  18. S3-Oski
    S3-Oski Member
    484
    Hi, could anyone tell me please would a light always come on the dash if a coilpack was playing up? Thanks
  19. s3dave
    10,110
    736
    No and often dont...
  20. S3-Oski
    S3-Oski Member
    484
    Thanks Dave,
  21. Sam_
    Sam_ Down under
    3,038
    480
    Does the BAM S3 have an ignition module? Mine dropped cylinder 3 tonight and I'm wondering if its coilpack or, if it has one, the ignition module. It's been idling a bit dodgy recently too.
  22. Nilz
    11,356
    894
    Sam, yours is most probably going to be a coilpack mate.
    Give Audi a call, they maybe able to swap it under the current recall that they have running.
