Drill,
I have just no idea mate. No idea at all now on what might be causing this.
At the weekend I went over things again. I checked, as best I could, all the vacuum hoses. The only one that caused a little concern was the fabric-braided vacuum hose going from the Fuel Pressure Regulator to the underside of the intake manifold. It isn't very tight at the FPR end, and it didn't take much the pull the hose off, even with its little clip still attached. So....could be loosing vacuum there perhaps.
Also at the weekend, I have re-fitted my old MAF. No point in "burning out" the new one, if it isn't solving the problem.
After that, I did basic settings on the MAF, TBA, did the lambda tests again, and did the throttle body and pedal sweeps. Need to check the pedal/TB sweeps, but everything seemed ok.
Today the car has had one slight instance of hesitation, but has regular surging on part-throttle.
I did try to service the Forge DV at the weekend, but couldn't get the b'stard thing undone. Looked a bit mucky on the side of the piston though. But its travel was smooth, and held in place ok with vacuum.
Also tried to fit the AmD intake pipe strengthening sleeve, just to rule out the pipe collapsing theory, but would it slide down the intake pipe - would it f###.
Not a good weekend really.
AL
AL
