loss of power in higher gears under load
barlow S3 Mar 12, 2013
  1. barlow S3
    barlow S3 New Member
    Hi Everyone
    When changing
    gear from the top end of 3rd gear to going into 4th, loses power. well that what it feels like[​IMG]. all the way up to aprox 5200rpm then mass boost is delievered.
    do you think it could be the actuator?
    turbo does not have viens and is not smoking or rattling so not turbo?
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Slipping Clutch?
  3. <tuffty/>
    21,974
    4,248
    Any fault codes? if the actuator was faulty you would most likely have all the boost and the fault would affect all gears... very much doubt its the issue...
  4. barlow S3
    don't think its clutch as feels more like loss of boost. There are no fault codes coming either.
  5. badger5
    9,639
    2,073
    logs would be helpfull
  6. Goubo1
    Goubo1 Well-Known Member
    958
    298
    Could it possibly be heat soak ??
  7. barlow S3
    wot is heat soak?
  8. badger5
    9,639
    2,073
    its like LOGs only hotter
    Seriously tho, do you have facility to vcds ay logs as without some data, its at bets poke and hope advise you will ever receive
