loss of power audi a4 2.5 tdi quattro
Johnboymason Apr 3, 2013
  1. Johnboymason
    Johnboymason Member
    73
    can anyone help me, im losing power on my 51 plate audi 2.5 tdi quattro, just replace water pump, timing chain pullys, thermostat, engine temp cencor, i can be driving along and my foot will be flat to the floor and it just creeps up to 2000 revs, but then 5 mins later the power comes gushing back :s ive checked boost pipes and all seem fine, no faults codes or anythink anyone any ideas please
  2. RobMorris
    RobMorris Member
    539
    10
    Sounds like limp mode - mine done it a couple of times after I ragged it - but once I turned the ignition off and on it was OK again?
  3. Johnboymason
    Johnboymason Member
    73
    well when am driving along say in second and a go to put my foot down theres just nothink there and it slowly climbs up the revs, but 5 mins later when ive still be driving the power comes back out of no where :S
  4. Johnboymason
    Johnboymason Member
    73
    when i put my foot down and change gear it also makes a chatter noise as if pipe off airbox and mass air flow is dissconnected :S
  5. jordanjcruiser
    jordanjcruiser New Member
    Hi john I recently purchased the exact same model audi A4 b6 2.5tdi but automatic. I am experiencing the exact same problem. Please let me know what u did. If I put my foot down nothing. Then later on it just works normally again when it gets to about 2500 revs. Iv been to so many machanic but I get different stories please help. At first I thought it was the clutch plate got it changed but same story. Please
  6. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,735
    2,604
    Sounds like an N75 issue with a lack of vacuum to the VNT actuator on the turbo. when it gets over 2K RPM does it run better ?. Try logging the boost / MAF outputs and see whats going on when the fault occurs.
    karl.
  7. jordanjcruiser
    hey there yes it does run better after 2k. Actually it boosts then if I let go of the gas n try again same thing happens
    it's very irritating especially if m in traffic.
  8. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    I would begin by checking the following areas/items;
    - MAF
    - Turbo VNT mechanism - clean.
    The fact that the power comes back out of the blue rules out boost pipework / vac lines for me - if it was constantly down on power then they would be an area to check thoroughly.
    Do you have access to VCDS? If so, you can log boost pressure, air intake volumes, fuel injection quantity - this can help drastically when trying to identify a problem that isnt obvious.
  9. jordanjcruiser
    Thanks a lot mate. I will take in today and let my machanic do all that. Cause m lost lol. Thanks a lot. Gdday
