Losing power
.... Jul 31, 2011
  1. ....
    .... Member
    Hi
    I need some help. My car is kind of losing power and at times it loses the pull it has.
    Im sure its due a fuel and air filter change. Could this be the case?
    Also my car only gives me 40 - 45 local miles to £10 and its a 1.9 tdi. Im sure that is less....
    Could the fuel filter change improve this?
  2. ....
    .... Member
  3. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,279
    166
    Its imposable to say over the net mate. Did it suddenly start to happen ? if so unlikely to be fuel filter. sounds like a turbo issue but you need to get it hooked up to VCDS first. Its easy enough to pull the air filter out for a few miles and see if that makes a difference.
  4. audicruiser
    audicruiser Audi Heaven
    1,865
    Do you always run it with so little fuel? If so you could be dragging rubbish from the bottom of the tank and blocking the fuel lines regardless of the filter...
  5. ....
    .... Member
    No it neva below a quarter tank.
    And noo it happened over time. But i could feel it loosing power
  6. ....
    .... Member
    Also if fuel filter needs changin could that be a cause for the low mileage?
  7. audicruiser
    1,865
    It is probably EGR related or breather on the 1.9 engine. You really need to get it scanned for fault codes and go from there...
