losing mpg??
Jay85 Dec 8, 2012
  1. Jay85
    Jay85 New Member
    27
    Hi all. I have an a4 1.9 tdi 130. I am now approaching 100k miles, and have noticed my mpg isn't what it used to be. Was normally averaging about 53-56mpg....but am now only acheiving 46mpg.
    is there any maintenance or servicing I can do that may help bring those figures back? Also due to it approaching the 100k mile mark, would it be worth considering giving a major service, cambelt change, plus anything else to prolong the life of the car, thus have many more years trouble free motoring?
    any advice be much appreciated
    cheers
  2. krisavant
    krisavant Active Member
    449
    61
    53-56mpg?? That's good!! Even 46 would be good for me right now.
    I'm currently in the process of trying to sort my mpg issues also. I'm only getting 39-42mpg (130 tdi avant).
    I think my 18" reps are killing my mpg mind.
    You could strip the egr and manifold out to give a good clean if never been done.
  3. Johnboymason
    Johnboymason Member
    73
    i need to strip my egr my mpg is **** like
  4. SL11CKK
    SL11CKK Active Member
    700
    I used to also get 50 mpg and dis used to show 60mpg at times and now dis has been reporting 30mpg with 25mpg in the morning. £30 diesel has only given me 145 miles only.
    Im thinking my car has some sort of fuel leak
  5. krisavant
    449
    61
    Mine had a slight leak at the back of the engine bay just under centre of windscreen. Easy to access and replaced clip with jubilee clip.
    Don't know if it's helped with mpg yet, haven't used the last fill up yet.
  6. SL11CKK
    700
    Is the pipe on the pump behind the.engine under the boost pipe?
  7. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    You get less mpg in winter you know! I average 42 in winter and 48 in summer
  8. krisavant
    449
    61
    Yes, checked every where else. Pump also looks fine and dry.
  9. marktdisport
    marktdisport Active Member
    1,195
    15
    Diesels are worse mpg in the cold petrols seem to improve slightly
  10. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    439
    I have a 3.0 TDI and have noticed a drop in feul economy.
    The cold weather has a lot to do with a drop in feul consumption. I was told that the diesel takes longer to warm up and work efficiently.
    I've noticed I'm getting less economy for my money.
  11. Jay85
    Jay85 New Member
    27
    with regards to the egr, will an egr blank improve things slightly? I was going to do this and clean intake manifold.
    What about things like coolant temp sensor/thermostat problems? I've seen a few posts about this but not sure how this would affect mpg??
  12. stu_m
    1,441
    EGR blank may improve slighly maybe 1-2 MPG if your lucky
    are you having problems with with your temp sensor or stat? if its reaching temperature then all is well and you dont need to change them
    a diesel takes a lot longer to warm up then a petrol especially in winter
    if you want to try and improve MPG then keep the heater on low around 20 - 22°c and the fan speed low this will help the engine warm up faster rather then sapping all the heat for the cabin
    oh and these engines like to be revved too I drive mine like I stole it and get better MPG then the missus who drives like a granny!
  13. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,228
    170
    EGR Blank in winter may worsen mpg, as it'll take longer to warm up.
  14. hades-
    9,481
    646
    as above clean egr
    maybe replace CTS doesnt always show up on a scan
    and the cold can knock quite a few MPG off
  15. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    Check you don't have a dragging brake or two.
    Both my B5s have had this, and the first symptom I noticed was the MPG dropped by a couple of points.
    Don't just feel the wheels after a run as I found they were not always hot - jack each wheel and spin it by hand. Any drag on a wheel will indicate dragging brakes.
  16. Johnboymason
    Johnboymason Member
    73
    any guides on removing egr ???
  17. stu_m
    1,441
    Yeah
    Buy some blanking plates or make your own
    Remove egr pipe fit plates job done
    It's only 4 bolts
