Give the following a good check over should be noticeable by a pink crusty antifreeze residue saying theres antifreeze in if youve just been topping up with water.
Water pump, cylinder head coolant housing and thermostat outlet.
mine did this and it was the black plastic coolant elbow on the rear of the cylinder head. Hairline crack along the bottom which only leaks under pressure. Fairly common failure.
