Looooong brake pedal travel
btmotorsport Apr 7, 2010
  1. btmotorsport
    btmotorsport Soon be christmas!!!!!!!!!!
    164
    Evening troops,
    I've recently noticed that my brakes aren't what they used to be. The pedal isn't as firm as it once was (good morning!), the car still slows with a small amount of pressure on the pedal but it's no where near as effective as it used to be. All the pads and dsics are good and the fluid was changed a few months ago. Any suggestions so I can get nice and hard again??!!! Car is 1.8t sport that's just passed 100k
  2. Purple Princess
    Purple Princess Moderator Staff Member Moderator
    1,044
    Air in the system, bleed it wont hurt :D
  3. btmotorsport
    164
    that's what i thought but it wasn't long ago that i bled them, gotta be worth a go tho! Out comes the ezibleed again
  4. Purple Princess
    1,044
    There are two bleed nipples on the master cylinder, be sure to bleed them too or you will have this prob all the time :D good luck
  5. btmotorsport
    164
    Good thinking! Tried it but still no joy along with bleeding everything else. I wonder if it could be the front discs, the pads are fairly new but the discs aint, they do have a slightly mottled effect rather than being shiny as you'd normally expect.
  6. btmotorsport
    164
    Just measured the discs and they are about 22mm thick, anyone know what the min thickness is?
  7. 1animal1
    9,978
    i have just had mine pressure bled and that has made a better difference than the two independent specialsistthat have had it before
  8. btmotorsport
    164
    been doing it with a pressure type system that runs off the spare tyre, it's a bit cheap tbh. Whats the system the garage used?
  9. tyler1
    tyler1 New Member
    10
    Is there much of a lip on the disks? this can push the pads/piston out slightly when driving meaning the next time you press the pedal some of the pedal travel has to close the gap before any real force is applied.
  10. Purple Princess
    1,044
    TBH it shouldnt make a diffrence if you do it yourself or othewise. I too use the spare tyre system lol.
    urm as for thickness I think they should be alot thicker than that, ill look on ELSWIN and let you know
  11. btmotorsport
    164
    the lip is a bit bad tbh, the back of the disc is worse. Got a set of delphi discs for £33 today so gonna stick em on tomorrow along with a good 8 hour detail!!!!
    Thank you all for ur help so far!
  12. Purple Princess
    1,044
    Grinder FTW :)
  13. 1animal1
    9,978
    I think pressure bleeding has a higher degree of success in my opinion based on the times ive had them done..... obviously if done correctly by the DIY method your gna see the same results, but the margin for error is much wider
    Stace im offended by your signature :)
  14. tyler1
    tyler1 New Member
    10
    Oldskool! like it
  15. btmotorsport
    164
    did that on my mates saab the other day, been stood for 18 months! Out with the grinder and a nice flappy disc!
  16. Matt82
    Matt82 Active Member
    2,365
    thickness of the disc will depend on what discs you have
    288 discs start at 25mm, with a min thickness of 22mm
  17. btmotorsport
    164
    cheers for all the input, turns out the discs were well past it! The backs of them were shocking, kinda annoyed with my self for letting them get so bad but hey ho, lesson learned!!
