looking for turbo application insight
a427tq Nov 19, 2007
  1. a427tq
    a427tq New Member
    I have a '99 TQ with an AEB. The turbo has blown. It's a 058145703L. I have a brand new 058145703N which "Only fits '03-'06 cab quattros with AMB" according to the dealer. They look identical in every way. Can I use this turbo on my car?
  2. Markey
    Markey Active Member
    2,175
    Im not sure do i could not tell you with out pics do you have any ?
  3. macca
    macca Member
    525
    if externally they look the same it maybe the compressor or turbine ratios are different, are oil feed and water feeds the same? actuator in the same place etc etc, without looking at them and finding the KKK part numbers i couldn't tell.
  4. waveform2
    waveform2 * J e d i *
    435
    Could a ring to Vag parts maybe enlighten you? They are pretty helpful, or at least have been in the past with me.
    Post up some pics some of the guys are VERY clued up on the turbo side of things.
  5. jcb
    jcb Active Member
    4,132
    13
    anything will work if you put enough effort in!
    get some pics posted
  6. Broken Byzan
    13,237
    466
    I would bet its a K03s and not a K03, if thats the case it will go straight on,no probs. And if you were to have the car tuned/chipped you could get more as the "S" turbo is slightly better
  7. a427tq
    a427tq New Member
    I appreciate the info. I did neglect to mention that the car has a TAP chip, but I imagine that that is not important. The props seem identical as well(same blade count anyway). I guess there is one way to find out...
    Does VAG have a tech number? I am unaware of one.
  8. Markey
    2,175
    As its off a quattro its more than likely going to be the S if it lookes the same just fit it, it wont do any damage as you can put a K04 on a standard car and nothing changes.
