Looking for recommendation to fit H&R Srings to S3 in Aberdeen/shire
Braveheart Jun 7, 2012
  1. Braveheart
    Braveheart New Member
    20
    As per title, looking for a recommendation of any garages to fit H&R springs to my S3. In or around the Aberdeen area is what I'm after. Thanks.
  2. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,554
    896
    Easy enough to do it yourself Kev. PM Paullie she's from up your neck of the woods.....she may have some good contacts that could assist.
  3. Kelvin_S
    Kelvin_S Member
    243
    Lol really? I was told don't ever f with the coil springs they're compressed and when it comes out it will take your head off!
  4. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,963
    722
    That's what spring compressors are for! ;)
    You could ask Ilim as well, I know that he's had springs put on and I'm pretty sure it didn't cost him too much all in, like <£50 I think (don't quote me on that though...).
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    forfar too far?
  6. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,496
    575
    I've done plenty of 8p A3/S3's and never needed to use my spring compressors. As the top nut is unscrewed it looses enough compression to just drop off.
    With the right tools its a fairly easy 2hr job!
  7. Braveheart
    20
    Yeah, I should really just do the job myself. Reasonably handy with a spanner, fitted coilovers to my Clio trackcar no probs. A guide would of course help to see if there's anything specific/peculiar with the S3 set-up.
  8. Braveheart
    20
    Is it necessary to get the alignment checked/reset after only a 25mm drop? Local Motorsport company has quoted £360 to supply and fit the springs including a full geometry check using Hunter equipment. About £80 of that is the geometry check.
  9. -Ju-
    2,496
    575
    Yeah you should get the alignment done as although its only 25mm, you are removing the strut and refitting it so will be slightly different.
    Same for the back, it will make a difference however slight.
    I had mine Hunter aligned for £65, its impressive what they can adjust, nothing like a tracking adjustment!
