looking for new springs - anyone tried these?
205man Sep 20, 2010
  1. 205man
    205man Active Member
    1,071
    13
  2. aragorn
    17,876
    687
    FK stuff is reasonable quality. I wouldnt say its up there with the big names like Eibach, Koni or Bilstein, but its not scraping the gutter either.
    Your Quattro is probably already about 15-20mm lower than "normal", so expect an extra 15-20mm from those springs.
    My only worry would be that they dont have different kits for different engines on quattro models.
  3. 205man
    1,071
    13
    I had thought about the fact they only list quattro as a generic spring to all engines
    But then thought how do we know that other suppliers don't do the same but just put a slightly different part number on and sell for twice the price lol
    what's the weight difference say between the 1.8t and 2.8 ?
  4. Daveiow
    Daveiow Member
    264
    Be intresting to so how these performed and what drop they would give cars with the sport suspension!.. I wish they would list the lowering rates properly!
  5. aragorn
    17,876
    687
    Theres about 50kgs between them i think.
    My handbook says kerb weight for the TQS is 1490 and kerb weight for a 2.8Q is 1540.
    I would imagine the front springs will be somewhere between 200-300lb-inch, which means you could be talking 10-20mm difference depending wether they're designed for a 1.8 or a 2.8.
    I would hazard a guess that they're for a 2.8 though, as 1.8 quattros are relatively rare when compared with the whole B5 production run.
  6. Daveiow
    Daveiow Member
    264
    so they might not even lower a 1.8t tqs ?
  7. aragorn
    17,876
    687
    Exactly.
    You just dont know where in the range they've aimed for. They might have gone somewhere in the middle, so you get a bit more than the specified drop on a V6 and a bit less on a TQS. Suck it and see i guess.
  8. voteforpedro
    voteforpedro Member
    632
    Lolz... ~£100 and a day's work to find out it raises your car 2mm and your car now handles like ****... no thanks. :p
  9. aragorn
    17,876
    687
    Well thats the whole point isnt it...
    You either spend lots of money on a kit thats going to work, or buy a cheap kit that may or may not do what you want.
  10. nwmlarge
    nwmlarge flat out
    219
    fit some jom coilovers if you are going for a cheap solution
  11. Daveiow
    Daveiow Member
    264
    no joms for quattros available (well not that ive found)
    In fact theres next to bugger all kits for the quattros that ive seen that would be any good..
  12. CraigG
    CraigG Member
    190
    H&R, KW, Bilstein, Eibach etc etc etc...
  13. Daveiow
    Daveiow Member
    264
    But do they list the lowering rate for the sport suspension ? or the same as others
  14. aragorn
    17,876
    687
    Very few manufacturers will list the lowering rate.
    The springs are progressively wound quite often for starters so they dont actually have a single rate, but if you think about it, its their "recipe". They're not going to publish the spring rates, because thats what they've spent the money developing.
