Looking for help to activate Bluetooth on Q5 in South Wales
solihul Jun 15, 2014
  1. solihul
    solihul Member
    60
    Hi,
    I have an Audi Q5, (2010) with HDD MMI Nav, SD card readers etc but no bluetooth,
    I have been told that the bluetooth hardware is installed in the car howver it was not selected as an option when the car was new and that it can be activated via vagcom and the hidden menu in the car,
    I am based in South Wales and was wondering if anyone could assist or knows anyone who is able to assist
  2. hades-
    9,481
    646
    if you get the codes etc
    I can do it any weekend in barry ?
  3. solihul
    solihul Member
    60
    Hi Mate,
    Thanks for your reply, I found the following instructions on the net but unfortunately they don't mean much to me, is this something that you are able to do:
    Please find below the different steps to activate the BT on a 3G MMI. To do so, you'll need the famous Vagcom.
    1) Enable the hidden menu [Vagcom]
    STG 5F (infotainment), Select
    STG adaptation -> function 10
    Canal number 06
    Value: 1
    2) BT activation [Hidden menu]
    To enter into the hidden menu, you have to press simultaneously [Car] + [Setup] for 6s
    Under Diagnostics \ Misc phone parameters\
    3) Reboot the MMI
    Press simultaneously 1 + 2 + 3 (this might take up to 60s)
    reboot MMI.jpg (46.41K)
    4) Infotainment adaptation with the BT [Vagcom]
    17 canaux - Bluetooth module (internal)
    Value: 1
    5) Enjoy
  4. hades-
    9,481
    646
    yeah I have vcds so shouldn't be a problem
    as long as its all fitted
  5. solihul
    solihul Member
    60
    Awesome,
    I'll pop over on the weekend if that's ok,
    Would you be able to activate the video in motion on the car as well,
    VIM login-code generator for MMI 3G
    This link give instructions on how to do it
