Looking for a sidelight fitting guide?
Khanage Dec 21, 2011
  1. Khanage
    Khanage Member
    227
    19
    I have halogen lights and want to replace the sidelights with some LEDs. I've ordered a pair that were recommended in this thread in the last post.
    I'm having no luck in finding a guide for the actual procedure. Could anybody give me a hand please?
    Thanks in advance
  2. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,051
    755
    K,
    open up the inner case of the headlamp, you will see the plug for your full beam, pull it out and remove that out the way. then put you hand in and find the wires and grab them firmly close to the holder and pull. it will come out.
    thanks
    Trups
  3. Triple.O.G
    Triple.O.G Active Member
    1,113
    Pull it HARD. mine were wedged in pretty solid, i gently got pliers on the in the end.
  4. Khanage
    Khanage Member
    227
    19
    I got the passenger side out quite easily. The drivers side however were a massive pain, had to take the pliers to them. The passenger side light works perfect whereas the driver side one flickers twice and goes out :(
    Guess I need resistors? Or can anybody recommend a set that definitely work. Trups, you got any in stock? I ordered these before I ordered the interior lights from you, which I'll be fitting after a quick bite
  5. razza1
    razza1 Well-Known Member
    3,075
    829
    shouldn't need resistors for sidelight leds...check the connections are making contact properly or try turning it round.
