Lookin for cheap miltek back box for s3sportback
reid1 Apr 15, 2012
Thread Status:
Not open for further replies.
  1. reid1
    reid1 Watch this space
    32
    Hi lookin for miltek back box for my s3 used pref thanks
  2. mjr901
    mjr901 Guest
    Not alot of point tbh.
    if you want a bit more noise, there's a flap in the standard exhaust that open and closes. hold that open with a bit of wire, that will give you more noise.
    ill keep my eyes open anyway
  3. reid1
    32
    Thanks for the heads up but still lookin for a miltek too even cat back would do :beerchug:
  4. Ben H
    Ben H On a journey...
    365
    19
    Ooh - what's this trick then? I've heard about the same on the Golf R32, but also that it isn't good for the engine's exhaust.
  5. audicruiser
    audicruiser Audi Heaven
    1,865
    It's a vacuum operated flap in the exhaust, its shut at low revs to keep the noise down and then opens at around 3000 rpm I think. It's called the "flapper mod" on the R32, the pipe is removed and plugged basically and so keeping the flap open all the time. Wouldn't of thought it does any harm to the engine....
  6. mjr901
    mjr901 Guest
    As far as I'm aware. you just disconnect the mechanism. and use a bit of wire to keep flap open. so I don't think it will harm the exhaust at all. I've been told it's an easy mod.
    Ive got my original exhaust in the garage. I'll have a look in more detail one of these days!
  7. reid1
    32
    I wish my s3 sounded like my mk5 r32 lol u can tell them a mile away
  8. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    884
    Any one got any more gen on this and will it have any detrimental effect on the running of the engine. I can't see there being any probs with it but just want to make sure before I have a go at it.
  9. mjr901
    mjr901 Guest
    I think what you do its take the pipe off the valve. Then seal it. then hold flap open with bit of wire.
    If you want some pictures of the part needed to be fiddled with, ill go out to my garage and take some? My standard exhaust with 1,500k is sat there...might as well make some use of it!
    Millteks should be standard!! :eyebrows:
  10. mjr901
    mjr901 Guest
Thread Status:
