Look what happened when the jack slipped !
vw754 Oct 25, 2012
  1. vw754
    vw754 vorsprung Durch Technik
    2,329
    58
    What can i repair this with?...sealant? chemical metal? the jack sliped and dug into the sill and made a cut,i dont want water getting in ,also cars going to a bodyshop in 2 weeks time bumper to be painted......any ideas what i should do here,there is a slight dent aswell.
  2. rOb_A
    rOb_A Active Member
    1,488
    the body shop will be able to sort this no problem. if your worried about water ingress before it going in, i'd gunk it with grease/underseal or if needs be a blob of silicone.
  3. vw754
    2,329
    58
    i wanted see if i can fix it myself.......bodyshop prob want 50 quid for that bit alone! i heard they can braize it or something?
  4. hades-
    9,481
    646
    duct tape
  5. C6 DRN
    C6 DRN living the dream Audi S3 Black Edition
    245
    70
    Could grab some p38 and just get a touch up aerosol yourself? might work im not the best with bodyshop stuff!
  6. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    For time being put some electrical tape over it till you can take to body shop for their suggestions.
  7. RobinA3
    RobinA3 Well-Known Member
    1,826
    46
    You'd be lucky if you got that fixed for £50 - you are looking at about £150 for a body shop to sort that out inc vat!
  8. Broken Byzan
    13,237
    465
    tbh given its the sill, it kinda needs welding as filling alone it isnt exactly the best thing for future MOTS
  9. GuyJ
    GuyJ Member
    58
    13
    I wouldn't advise putting grease/silicone on there as if you do want it painted you will have to panel wipe (de-silcone for ages!) To do it right it needs welded, filled then painted. luckily, its on the sill and tbh you could repair yourself.
    If you get some one to weld the "gash" up. Some p38 (filler) as someone has already said. Then some rattle can stone chip (the rough effect) and rattle can base coat and lacquer! sorted :)
    I can give you some advice if you would like.
  10. GuyJ
    GuyJ Member
    58
    13
    Beat me to it! :(
  11. rOb_A
    rOb_A Active Member
    1,488
    if grease/silicone is used as a temporary measure, id see this as no problem. The at paint work around hole and the hole will be ground back prior to welding. this would remove all contaminants. so dont really see any issue's but I may be wrong :unsure:
  12. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    883
    Have you ever seen the tap test that MOT testers do on the sills of cars. Their toffee hammer would pick up a filler repair in no time at all unless you know the tester ;-)
  13. murran
    murran Well-Known Member
    1,545
    39
    its a scratch and a little dint isnt it? last thing you want is welding on a sill on a 5 year old car. welding encorages rust, it heats up the surrounding metal disturbing the original paint and will melt the wax off the panel on the inside. touch it up with primer and colour and leave it.
  14. murran
    1,545
    39
    naaaa. im a tester, you wouldnt pick up on a tiny skim of filler on such a localised area on a sill ever with it.
    infact i havent picked up the corrosion hammer since the last ford ka i tested about 2 months ago!
  15. GuyJ
    GuyJ Member
    58
    13
    Yeah suppose. I didn't mean to shoot your idea down :)
    It should be welded for sure and a skim of filler. if its a big dent get the body shop to pull it out and weld it and just paint it yourself?
    Mask it with a soft edge. (doubled of masking tape) with it being the rough texture you shouldn't see it.
  16. GuyJ
    GuyJ Member
    58
    13
    Why would you check a ford KA? They never rust ;) haha..... I would use a big hammer for testing that. 14lb and smash it up!
  17. Brodster
    3,548
    883
    Thats good to know as I've seen several of them go hammer and tongs on a filler repaired sill. I wasnt too chuffed when I had to get it welded properly.
  18. vw754
    2,329
    58
    THEY PROBABLY WOULD.....especially if im spending 400 with them anyway
  19. vw754
    2,329
    58
    i wouldnt like get it welded......its so so tiny,just a slit on a piece of paper......What about dabbing in some chemical metal then touching in with touch up paint,it'll be filled,solid and end of.
  20. vw754
    2,329
    58
    Thats great.....alot of m.o.t testers see the cars mint on the body,dont bother with the hammer
  21. GuyJ
    GuyJ Member
    58
    13
    The correct way IMO is to weld it. Just fill and paint if you wish. You will need to stone chip it to get the rough texture back though.
  22. murran
    1,545
    39
    the picture is a little rubbish, has it actually cut a slit into the sill (as in a hole) or not?
  23. Broken Byzan
    13,237
    465
    It seems like you are going to bodge it up anyway, so I guess it's up to you, for £50 is it really worth bodging????
  24. Ironborn
    Ironborn English...not so good
    1,179
    227
    Time for some side skirts :p it will go right over that.
