Longlife oil change Vs "Segment 2" oil change...
Ads Nov 22, 2011
  1. Ads
    Ads License to drive
    8,230
    608
    My car is due a service, or basically, an oil change.
    I've been quoted the following:
    Independent VAG specialist - £155 using longlife oil.
    Audi - £149 for a "segment 2" oil change (seen here under Affordable servicing, Interim Service --> Affordable servicing < Servicing with Audi < Owners area < Audi UK)
    Audi
    - £238 using longlife oil.
    What oil is actually used by Audi when doing a segment 2 oil change?
    And is it better to use the longlife oil?
  2. cloughy
    cloughy Member
    515
    This is the invoice I got on my £149 service, says SYNTA5LT[​IMG]
  3. Ads
    8,230
    608
    Thanks a lot for that mate.
    Looked it up and going by your invoice the oil used is Quantum Synta Semi-synthetic 10w40.
    Never heard of it.
    Anyone??
  4. cloughy
    cloughy Member
    515
    that got me thinking, I don't want **** oil in my car! found this...
    Engine Oils - Quantum (these are made by Castrol for Volkswagen Group UK):
  5. Ads
    8,230
    608
    Yeah I saw that too.
    Also, are you going to know which oil to use if you need to top up??
  6. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,487
    I used to use Synta Silver in my old 16v engines (Mk2 Golf).
    I thought the new engines needed a 5w30, not a 10w40?
    I can never make out whether they make a science out of oil to be bloody awkward and keep charges up, or whether long life oil is worse for your car with longer service intervals (esp. on modded cars). I used to change every 5k until oil got to £80 a pot.
    As long as its got the right VW rating (the 500 numbers), then surely it will be OK as an interim.
  7. Ads
    8,230
    608
    I losing the will to live, if i'm honest. Think I'm just going to pay the indie £155 to use longlife oil.
    My last service was a full longlife variable service, but my car must've been set to fixed interval because 4k miles later and a year to the day it is telling me it wants pampering again.
  8. cloughy
    cloughy Member
    515
  9. Ads
    8,230
    608
    You sure that's right? Different part number....
  10. Ads
    8,230
    608
  11. cloughy
    cloughy Member
    515
    Sorry your right that was the wrong link
    Quantum Synta, 10w40, VW 500.00/505.00, ACEA: A3/B3, API SL/CF; (semi-synthetic)
    ZGB 115 QLB 004 05 - 1 lit
    ZGB 115 QLB 004 06 - 5 lit
    ZGB 115 QLB 040 7L - 20 lit
    ZGB 115 QLB 004 08 - 208 lit
    This would be the correct one going on the part number on my invoice, but then that site says don't use on PD engines??? Very odd
    http://www.vwspares.co.uk/product_info.php?products_id=1137
  12. Ads
    8,230
    608
    It's SO cheap as well. £13.50 +vat for 5 litres!!
  13. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    I've just bought some Mobil 1 ESP fully synthetic for my car along with a new oil filter (under £60 delivered), but it's not 5W-40, it's 5W-30 as recommended for the 8P S3 on the Opie Oils website. As my car is modded, I want to change every 6K miles, but do you guys think the oil I've bought will be OK? Just want to make sure before I get the oil change done :uhm:. Thanks in advance :wub: x
  14. Stuart1441
    Stuart1441 New Member
    Im also thinking of an oil change and have been looking into the mobil 1 oil for my S3, i only want to use the best but is there any benefit of using a premium oil over the audi oem stuff?
  15. cloughy
    cloughy Member
    515
    Mobil 1 ESP meets the latest VW/Audi specification for petrol engines which is VW 504 00
    The oil you have ordered is more than ok
  16. 5ean
    5ean S3 Owner VCDS Map User
    415
    I would also like to jump in on this thread if i may.. My S3 just got a new engine and i've now done the usual 1000 mile run in.. In fact i've done just over that but when the engine was put in it went on a long life service plan. I want to take it off of that and do fixed intervals, probably every 6-8 months for an oil change. What''s the best oil to use?
  17. a3tdi2001
    a3tdi2001 Member
    437
    Hi. You might want to go to Audi and get that oil changed for Quatum Platinum, or Longlife III if you have a DPF, if they have actually filled your car with Synta. They should do this FOC if they have used Synta.
  18. cloughy
    cloughy Member
    515
    Thanks, you've reminded me? I'll send Audi an email. When I saw the website say don't use in PD engines I thought it was a bit odd!
  19. cloughy
    cloughy Member
    515
    strange that my turbo starts to go after the oil change....
    Haven't got a hope in hell pinning that on Audi! lol
  20. Paullie
    2,076
    288
    That's excellent, Cloughy. Thanks for that! :wub: x
  21. cloughy
    cloughy Member
    515
    If you took it to Audi I would imagine they would use the platinum stuff on fixed servicing, it meets the latest spec
    http://www.vwspares.co.uk/quantum_oils.php
  22. Harrelson
    Harrelson Member
    173
    fully synthetic oil is the best for modern engines (they resist oxidation at higher temps so lubricate for longer)
    mine has just hit 19k miles after 2 years and DIS is telling me i have 5 days or 400miles to next service/oil change. quoted £130 at an audi specialist for fully synthetic plus £50 for aircon service. i will top up the other fluids at my own expense
    considering im paying around £200 every 2 years for service, £20/yr tax and im getting around 50mpg in city driving, my 1.6tdi has been a cheap car to run :)
